440 Oil Pumps #515211
11/03/09 12:38 PM
11/03/09 12:38 PM
Portland Oregon
JohnnyBeGood Offline OP
Portland Oregon
I am trying to decide which way to go with my 440 street build. Milodon or the ebay special blueprinted melling pump?
Re: 440 Oil Pumps [Re: JohnnyBeGood] #515212
11/03/09 01:50 PM
11/03/09 01:50 PM
an8sec70cuda Offline
For normal street builds or mild street/strip setups, I just use a Melling HV oil pump. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 440 Oil Pumps [Re: JohnnyBeGood] #515213
11/03/09 02:48 PM
11/03/09 02:48 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
The Melling HV is all you need. Don't forget it uses longer bolts.
Re: 440 Oil Pumps [Re: an8sec70cuda] #515214
11/03/09 03:18 PM
11/03/09 03:18 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I use a std. volume pump on my 440. You will find that most racers use the stock pump. The reason is the HV pumps more oil than the motor needs. HV pumps = HP loss, worn timing chains and oil blowing past the seals. I do port out and remove the as cast finish and radius the sharp turns on the internal passages on the stock pump to make it more efficent.
Re: 440 Oil Pumps [Re: ccdave] #515215
11/03/09 04:11 PM
11/03/09 04:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
For a full rebuild, a standard pump should do fine. I did a backyard hone'n're-ring so I went with a hv pump. The excess pressure is by passed right back to the pan, so I don't think it's a problem at all. But then I do also run a 7 quart pan/pickup. On a worn motor or one with fully grooved bearings, I'd say the HV is a good choice, on a fresh motor with regular bearings IMO the HV pump is unnecessary.
Re: 440 Oil Pumps [Re: ccdave] #515216
11/03/09 05:36 PM
11/03/09 05:36 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
The stock 383HP, 440HP and 426 Street Hemi all came with the same sized standard-volume oil pump rotors and all those engines were ran hard back in the day. As stated, the standard oil system is beefy enough for most applications.
Re: 440 Oil Pumps [Re: DaytonaTurbo] #515217
11/03/09 05:36 PM
11/03/09 05:36 PM
A std vol pump. There have been a few reported failures of Melling HV pumps. Melling and Milodon are both good brands. What brand are the blueprinted ones on eGay? whichever one you go with clean it/check the 3 or 4 clearances that there is a spec for & ESPECIALLY make sure it turns freely & no binding & I would port it to up the flow & reduce the stress on the shaft/gears.
