Electric Choke connection #515090
11/03/09 08:52 AM
11/03/09 08:52 AM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Where should I connect hot from the electric choke? I understand it should be from a source that is hot only when the engine is running, but am not sure where that would be? The ballast resistor?? If so which side??
Thanks in advance.
Re: Electric Choke connection [Re: slowpoke] #515091
11/03/09 09:10 AM
11/03/09 09:10 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
factory took it from the dark blue wire off the same side as the ballast resistor.
Re: Electric Choke connection [Re: slowpoke] #515092
11/03/09 10:22 AM
11/03/09 10:22 AM
from the choke run a wire down several inches & tap into the wiring harness running along the inside edge of the valve cover & tap into the blue wire thats going to the alt field lead (on a 2 field terminal alt)
Re: Electric Choke connection [Re: RapidRobert] #515093
11/03/09 09:35 PM
11/03/09 09:35 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
as stated
Re: Electric Choke connection [Re: slowpoke] #515094
11/03/09 10:18 PM
11/03/09 10:18 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Thanks in advance.
What year? If its 73 or newer its already there. If its older than 73 the previous posters gave you the correct way to do it.
Re: Electric Choke connection [Re: NachoRT74] #515095
11/03/09 10:22 PM
11/03/09 10:22 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Thanks for the info guys!!!
