Page 1 of 3 1 2 3
contradictions, 1st or 2nd gear burnouts? #514756
11/02/09 11:04 PM
11/02/09 11:04 PM
fullmetaljacket Offline OP
I've heard for years to always start your automatic burnouts on first gear, then quickly switch over to 2nd from there on for the rest of the burnout.
I just started doing 2nd gear burnouts and every thing seems well, But........
Now my transmission builder, who is probably the best in the North East as far as 27's and 04's has scolded me for starting out in 2nd gear.
He said that it puts unnecessary strain on the 2nd gear bands aside from other parts in the box, so I should go back to my 1st gear burnouts immediately. What gives on others opinions?
Re: contradictions, 1st or 2nd gear burnouts? [Re: fullmetaljacket] #514757
11/02/09 11:09 PM
11/02/09 11:09 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Chrysler/Amer. Mtrs. “727”, “904”, “998” & “999” Transmissions
All water burnouts should be started in second gear and shift to third if necessary. If you should
start burnout in first, shift immediately to second before tires come out of water. No matter whether
it be second or third gear you are in as you come out of the water, you should start to deaccelerate
engine or do a power burnout directly to the staging line being sure tires never grab dry pavement.
from Turbo Action website...
Tony
70 AARCuda Vitamin C
Re: contradictions, 1st or 2nd gear burnouts? [Re: fullmetaljacket] #514758
11/02/09 11:10 PM
11/02/09 11:10 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Lee,I have been told by many to start in 2nd and go into high.With the HP your producing,after goin' through the water box,2nd will spin em no problem.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: contradictions, 1st or 2nd gear burnouts? [Re: hemi-itis] #514759
11/02/09 11:26 PM
11/02/09 11:26 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
2nd NEVER 1st with a 3 speed.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: contradictions, 1st or 2nd gear burnouts? [Re: bigtimeauto] #514760
11/02/09 11:34 PM
11/02/09 11:34 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Lee I would always start in 1st, 2,3, and never til this day had a problem
Re: contradictions, 1st or 2nd gear burnouts? [Re: bigtimeauto] #514761
11/02/09 11:35 PM
11/02/09 11:35 PM
For years, I use to start in 1st and then quickly switch over to 2nd.
Now as I said, I've tried the 2nd into 3rd and no problems so far. I got scolded and warned.
Felt confused. Don't wanna hurt the box.
Re: contradictions, 1st or 2nd gear burnouts? [Re: fullmetaljacket] #514762
11/02/09 11:38 PM
11/02/09 11:38 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
The last three years or so I've just been doing high gear burnouts, works great for me, no problem at all getting them going, just whack the throttle and tire speed jumps right up.
Re: contradictions, 1st or 2nd gear burnouts? [Re: fullmetaljacket] #514763
11/02/09 11:40 PM
11/02/09 11:40 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Lately I use a Glide nda Valiant, but my other cars have 727, I guess its debatable, Curtis, also starts out in 1st.
Re: contradictions, 1st or 2nd gear burnouts? [Re: B1KILLER] #514764
11/02/09 11:45 PM
11/02/09 11:45 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Re: contradictions, 1st or 2nd gear burnouts? [Re: B1KILLER] #514765
11/02/09 11:46 PM
11/02/09 11:46 PM
Who's on 1st? what's on 2nd? 3rd is there! LOL.
Re: contradictions, 1st or 2nd gear burnouts? [Re: fullmetaljacket] #514766
11/03/09 12:12 AM
11/03/09 12:12 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
The ONLY reason to use 1rst gear is if you have a big tire and low HP and are just unable to spin the tires using second or third.
And, then you need to shift to second as soon as practical.
I do my burnout in second and never shift. Just boot the throttle in second. Don't be timid!
SRT DEMON ONE SEAT
Re: contradictions, 1st or 2nd gear burnouts? [Re: Ron Silva] #514767
11/03/09 12:30 AM
11/03/09 12:30 AM
Recently starting in 2nd gear has not been a problem for me. The tires break with ease and buzz up fast from there.
Re: contradictions, 1st or 2nd gear burnouts? [Re: fullmetaljacket] #514768
11/03/09 12:43 AM
11/03/09 12:43 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Do you have a LBA valve body?
If you don't, Start in 2nd gear.
Re: contradictions, 1st or 2nd gear burnouts? [Re: fullmetaljacket] #514769
11/03/09 12:45 AM
11/03/09 12:45 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I've always started in second. I can't believe the too much strain on the band arguement.
The tires are wet, and break loose with virtually no throttle. WAY more strain on the band when it bangs it into second on the one/two shift at 5800rpm
FWIW, it wa a tranny guy who told me to always start in second
Re: contradictions, 1st or 2nd gear burnouts? [Re: dave571] #514770
11/03/09 12:55 AM
11/03/09 12:55 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Gotta Line-Loc?? Like Dave says....then you wouldn't need hardly any throttle to bust the tires loose in 2nd gear.
I've been staying in 2nd gear alot more lately thru the whole burnout. With the 6Pak, if I shift into high gear at the wrong time, the engine will try to start bogging down, so I give it some more throttle and the tac heads for the moon when the end carbs slam open. Thank God for Rev-Limiters!!
Re: contradictions, 1st or 2nd gear burnouts? [Re: fullmetaljacket] #514771
11/03/09 02:14 AM
11/03/09 02:14 AM
Cab_Burge Online work
Cab_Burge  Online Work
On all Mopar 904 types and 727 with manual valve bodys, back in the early 1970s at one of the Mopar performance drag race seminars, I was told to never do a water burn out starting in low gear and then shift it into 2nd or 3rd, never Shame on your trans builder I set the line loc, hit it in second and shift into high as soon as I know the tires are spinning in 2nd gear, I try to keep the rpms 200 to 300 above the stall of the converter or more. Once the tires are smoking in high gear I do a count, 1 to 4 depending on tires and track conditions, and then let go of the line loc and let the car drive out of the water at very light throttle, I let off as soon as I feel the tires start to grab. Ready to go to the starting line now and away
Re: contradictions, 1st or 2nd gear burnouts? [Re: fullmetaljacket] #514772
11/03/09 03:40 AM
11/03/09 03:40 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
depends on the valve body.
If using a stock valve body, start in manual low (first) because this will apply the rear (low/reverse) band, then shift to second.
Any other gear selection with a stock valve body will have the transmission start in low/breakaway (first gear with out rear band apply.)
With a true manual valve body, use second gear.
Re: contradictions, 1st or 2nd gear burnouts? [Re: 451Mopar] #514773
11/03/09 04:29 AM
11/03/09 04:29 AM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
But what if you shift from 2 to 3:d gear with to little power.
And you try it over and over again, will you burn the transmission.
I have a friend thats killing his tranny this way.
Or is he hurting it??
The oil smells burnt.
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: contradictions, 1st or 2nd gear burnouts? [Re: MrSixpack] #514774
11/03/09 07:47 AM
11/03/09 07:47 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
racing 32 years 2nd to high set line lock crack the throttle to 6000 shift to 3rd .
However i do drive mine out hard like pro stocks up to the line in 3rd .That was with 904s and 727s.
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: contradictions, 1st or 2nd gear burnouts? [Re: 10 o to go] #514775
11/03/09 07:52 AM
11/03/09 07:52 AM
most drum explosions happen during the burnout. if you are using a stock drum, it is a must to start in 2nd gear. if that stock drum lets go in 1st gear or in the burnout box, your going to have a serious mess and maybe 1 less leg or foot.that drum with come right through the floorboard.
Page 1 of 3 1 2 3
