Re: E-body- 2spd wipers to 3 speed- conversion?
[Re: Kirby]
#514142
11/02/09 12:53 PM
11/02/09 12:53 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
need: switch main linkage ( not the pivots or side to side link ) motor crank motor NOTE...depending on year linkage changes the joint/bushing kind ( brass, teflon, retainers ), so thats the hardest part to match ( unless you find a complete matching linkage and pivot set ) B and E are the same... some informative thread I made ( full info ) when making the conversion http://www.dodgecharger.com/forum/index.php/topic,34649.0.htmlalso full info about how the 2speeds with concelead wipers works &/or is assembled
[Re: NachoRT74]
#514143
11/02/09 02:05 PM
11/02/09 02:05 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
70 b is not the same as any e.70-71 e is different than 72-74.If you use everything from the same year it will work
NS1AAR
[Re: ns1aar]
#514144
11/02/09 02:07 PM
11/02/09 02:07 PM
NachoRT74
Valencia, España
of course I'm talking between E bodies and 71/74 B bodies, 70s B didn't get concelead wipers
[Re: NachoRT74]
#514145
11/02/09 02:28 PM
11/02/09 02:28 PM
ns1aar
ontario calif
I think that the arm that goes from ther crank to the left wiper is also different on the 71 up b body the cowel is taller.I'd have to look at the set I have at home latter today
NS1AAR
[Re: ns1aar]
#514146
11/02/09 02:35 PM
11/02/09 02:35 PM
NachoRT74
Valencia, España
no, they are same length on everything.
a matching complete linkage set will fit on either one of them.
the only diff ( I think is a 70 E body deal ) is the driver side pivot, being a little bit larger plate than the rest making one of the screws won't match on an B body, but not sure if is really a 70 deal or all E bodies though.
BTDT.
[Re: NachoRT74]
#514147
11/02/09 02:38 PM
11/02/09 02:38 PM
ns1aar
ontario calif
The cross link between the piviots is different between the b and e
NS1AAR
[Re: ns1aar]
#514148
11/02/09 03:22 PM
11/02/09 03:22 PM
NachoRT74
Valencia, España
mmm, well maybe... I found Diff PNs on them on my 74 catalog, but dunno really if because the diff bushing kind attaching or whatever reason.
I'm pretty sure a buddy with a 70 Chally got its wiper assembly from a 73 Charger I parted out, but dunno if he used only the motor or AAAALL the assembly.
[Re: NachoRT74]
#514149
11/02/09 09:41 PM
11/02/09 09:41 PM
ns1aar
ontario calif
Per the 70-71 parts book the only parts that are the same on the 71 b body asthe 71 ebody are the motor,crank and clips(indicating they use the same bushings)The 71-74 cowel is taller than the e body
NS1AAR
