E-body- 2spd wipers to 3 speed- conversion? #514141
11/02/09 12:12 PM
11/02/09 12:12 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Can I just take the parts off the back of the 2 speed wiper motor, and put them on the 3 speed motor? If not - what parts am I looking for? Looks like it would all bolt right together?
Re: E-body- 2spd wipers to 3 speed- conversion? [Re: Kirby] #514142
11/02/09 12:53 PM
11/02/09 12:53 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
need:
switch
main linkage ( not the pivots or side to side link )
motor crank
motor
NOTE...depending on year linkage changes the joint/bushing kind ( brass, teflon, retainers ), so thats the hardest part to match ( unless you find a complete matching linkage and pivot set )
B and E are the same...
some informative thread I made ( full info ) when making the conversion
http://www.dodgecharger.com/forum/index.php/topic,34649.0.html
also full info about how the 2speeds with concelead wipers works &/or is assembled
Re: E-body- 2spd wipers to 3 speed- conversion? [Re: NachoRT74] #514143
11/02/09 02:05 PM
11/02/09 02:05 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
70 b is not the same as any e.70-71 e is different than 72-74.If you use everything from the same year it will work
NS1AAR
Re: E-body- 2spd wipers to 3 speed- conversion? [Re: ns1aar] #514144
11/02/09 02:07 PM
11/02/09 02:07 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
of course I'm talking between E bodies and 71/74 B bodies, 70s B didn't get concelead wipers
Re: E-body- 2spd wipers to 3 speed- conversion? [Re: NachoRT74] #514145
11/02/09 02:28 PM
11/02/09 02:28 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
I think that the arm that goes from ther crank to the left wiper is also different on the 71 up b body the cowel is taller.I'd have to look at the set I have at home latter today
NS1AAR
Re: E-body- 2spd wipers to 3 speed- conversion? [Re: ns1aar] #514146
11/02/09 02:35 PM
11/02/09 02:35 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
no, they are same length on everything.
a matching complete linkage set will fit on either one of them.
the only diff ( I think is a 70 E body deal ) is the driver side pivot, being a little bit larger plate than the rest making one of the screws won't match on an B body, but not sure if is really a 70 deal or all E bodies though.
BTDT.
Re: E-body- 2spd wipers to 3 speed- conversion? [Re: NachoRT74] #514147
11/02/09 02:38 PM
11/02/09 02:38 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
The cross link between the piviots is different between the b and e
NS1AAR
Re: E-body- 2spd wipers to 3 speed- conversion? [Re: ns1aar] #514148
11/02/09 03:22 PM
11/02/09 03:22 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
mmm, well maybe... I found Diff PNs on them on my 74 catalog, but dunno really if because the diff bushing kind attaching or whatever reason.
I'm pretty sure a buddy with a 70 Chally got its wiper assembly from a 73 Charger I parted out, but dunno if he used only the motor or AAAALL the assembly.
Re: E-body- 2spd wipers to 3 speed- conversion? [Re: NachoRT74] #514149
11/02/09 09:41 PM
11/02/09 09:41 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Per the 70-71 parts book the only parts that are the same on the 71 b body asthe 71 ebody are the motor,crank and clips(indicating they use the same bushings)The 71-74 cowel is taller than the e body
NS1AAR
