Jaybirds 67 Belvedere #513656
11/01/09 09:55 PM
11/01/09 09:55 PM
Seattle Wa
PowerWagonDude Offline OP
Seattle Wa
This Jaybirds 67 Plymouth Belvedere. It sat here in the bushes since 2000.
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513657
11/01/09 09:58 PM
11/01/09 09:58 PM
Seattle Wa
Seattle Wa
We towed it to the shop and started cleaning out 10 yrs worth of garbage
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513658
11/01/09 10:00 PM
11/01/09 10:00 PM
Seattle Wa
Seattle Wa
Today it got new tires that don't go flat and a much needed wash job
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513659
11/01/09 10:02 PM
11/01/09 10:02 PM
Seattle Wa
Seattle Wa
getting cleaner
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513660
11/01/09 10:05 PM
11/01/09 10:05 PM
Seattle Wa
Seattle Wa
It has a low mileage 440 from a C body that got new new head gaskets, timing chain set and oil pump. It has new dual exhaust with Hemi turbo mufflers
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513661
11/02/09 02:34 AM
11/02/09 02:34 AM
California
darkrider2 Offline
darkrider2  Offline
California
Looks good, what kind of direction are looking to go with the car?
Re: Jaybirds 67 Belvedere [Re: darkrider2] #513662
11/03/09 11:22 PM
11/03/09 11:22 PM
Seattle Wa
Seattle Wa
The objective is to build a GTX clone that will be drag raced and street driven. Hopefully mid 12 second ETs in street trim. It will be dark purple with custom interior. The 440 is from a 67 New Yorker with 43,000 original miles. It still had the plastic timing gear with no teeth missing. A bigger cam and ported heads are in its future
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513663
11/03/09 11:34 PM
11/03/09 11:34 PM
KS.
The70RT Offline
The70RT  Offline
KS.
Cool car. I always wanted one for a Petty clone.
Re: Jaybirds 67 Belvedere [Re: The70RT] #513664
11/09/09 10:12 AM
11/09/09 10:12 AM
Boswell, PA
67PLY Offline
67PLY  Offline
Boswell, PA
Nice car.......I have had mine for past 22 years. Bought it in '87 from the original family. Had one repaint and all original drivetrain. 318/727.
Re: Jaybirds 67 Belvedere [Re: 67PLY] #513665
11/11/09 10:09 AM
11/11/09 10:09 AM
Jersey shore
Gary67 Offline
super street
Gary67  Offline
super street
Jersey shore
Looks good, I'm surprised how well the trim/bumpers held up after sitting for so long.
Re: Jaybirds 67 Belvedere [Re: Gary67] #513666
12/05/09 10:34 PM
12/05/09 10:34 PM
Seattle Wa
Seattle Wa
New battery and Holley 750 Double Pumper carb
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513667
12/05/09 10:36 PM
12/05/09 10:36 PM
Seattle Wa
Seattle Wa
Holley Carbs rock. New MP cam and Torker II intake coming soon
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513668
12/06/09 12:20 AM
12/06/09 12:20 AM
Chandler, AZ
cirrusaero Offline
cirrusaero  Offline
Chandler, AZ
looks like a pretty decent project car. if you are planning on getting rid of the lower trim panels let me know.
68 Charger 605 Hemi, Keisler 5spd, Pro-touring
66 Coronet 2dr post
66 Satellite
Re: Jaybirds 67 Belvedere [Re: cirrusaero] #513669
12/06/09 06:53 PM
12/06/09 06:53 PM
Callands, VA
Tubbed440 Offline
Tubbed440  Offline
Callands, VA
I've always wanted one of those cars. I saw one that exact same color at Carlilse this past year - interesting color - and you don't see it often. Nice project, and good luck getting her together. Keep the pics coming!
Re: Jaybirds 67 Belvedere [Re: Tubbed440] #513670
01/10/10 11:17 PM
01/10/10 11:17 PM
Seattle Wa
Seattle Wa
Its time to freshen up the motor for 2010
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513671
01/10/10 11:20 PM
01/10/10 11:20 PM
Seattle Wa
Seattle Wa
So we pulled it out Redneck style
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513672
01/10/10 11:21 PM
01/10/10 11:21 PM
Seattle Wa
Seattle Wa
Which intake is better?
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513673
01/10/10 11:28 PM
01/10/10 11:28 PM
Seattle Wa
Seattle Wa
Here is Jaybird working on his 440. It will be getting a valve grind on the 915 heads, MP cam 284/.484(He likes the MP cams so dont say Voodoo cams are better ), and the Edelbrock Torker II with Holley 750 DP. He doesn't like headers so these manifolds will have to work. Some HP manifolds would be nice ife he could get a good deal
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513674
01/10/10 11:51 PM
01/10/10 11:51 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The Torker (or any other single plane design) will be a slug at lower RPMs unless you do a healthy cam swap.
If just bolting one of those intakes on a 100% stock 440 the stock dual plane intake will net you better overall performance.
Re: Jaybirds 67 Belvedere [Re: ScottSmith_Harms] #513675
01/11/10 12:17 AM
01/11/10 12:17 AM
Seattle Wa
Seattle Wa
A new High Stall torque converter to compliment the cam is also on the list. Should work good with the 67's higher compression and the 3.55 gears. We also ordered up a set of later style pushrods and new valve springs to match the cam
