Broke off bolt in crank pully? Is that OK to leave? #513154
11/01/09 01:04 PM
11/01/09 01:04 PM
IL
hemiclone Offline OP
mopar addict
mopar addict
IL
I was tightening down the 5 or 6 bolts that are for the lower crankshaft pulley(for the belts)on my 440 and one of the bolts broke off..can I just leave it that way or will it throw the motor off balance?
Thanks!
Re: Broke off bolt in crank pully? Is that OK to leave? [Re: hemiclone] #513155
11/01/09 01:07 PM
11/01/09 01:07 PM
California
mickm Offline
mickm  Offline
California
despite the balance issue, there is now one less bolt holding that pulley in place.
take the time and do it right, if for nothing more than peace of mind.
take it out.
Re: Broke off bolt in crank pully? Is that OK to leave? [Re: mickm] #513156
11/01/09 01:10 PM
11/01/09 01:10 PM
IL
mopar addict
mopar addict
IL
Thanks for slapping some sense into me! I was on a roll and just wanted to keep going...sometime you gotta sit back and be patient.
Re: Broke off bolt in crank pully? Is that OK to leave? [Re: hemiclone] #513157
11/01/09 01:48 PM
11/01/09 01:48 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Yep...Sometimes it is 2 steps forward and then 3 back but it is worth it to get it right....
Re: Broke off bolt in crank pully? Is that OK to leave? [Re: hemiclone] #513158
11/01/09 02:11 PM
11/01/09 02:11 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I ran with one missing on my 440 for almost 10 years.The damper had one broke when I bought it.Never hurt a thing.I doubt that it would have any affect.If its out you might as well fix it though.Rocky
Chrysler Firepower
Re: Broke off bolt in crank pully? Is that OK to leave? [Re: therocks] #513159
11/01/09 02:48 PM
11/01/09 02:48 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The bolt weight is insignificant when it's that close to center.
Re: Broke off bolt in crank pully? Is that OK to leave? [Re: John_Kunkel] #513160
11/01/09 02:57 PM
11/01/09 02:57 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
i only run 5 bolts in my crank pulley due to the pulley having an offset hole and the balancer does not. Never had a problem up to 7k rpm
Re: Broke off bolt in crank pully? Is that OK to leave? [Re: prochargedhemi] #513161
11/01/09 03:27 PM
11/01/09 03:27 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Most of the time you can unscrew the bolt out the back when you remove the balancer. I had to a couple of times in the last 35 years.
Re: Broke off bolt in crank pully? Is that OK to leave? [Re: Mopar-Al] #513162
11/01/09 07:07 PM
11/01/09 07:07 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
Without the pulley on it, I've been able to back broken bolts out with my finger before. Just depends on how and why it broke. Just put the tip of your finger on the end and spin and see if it comes out. I've also had to drill them out and helicoil them as well and that takes more work.
If you're in a rush, see if you can get it to back out with the tip of your finger. I wouldn't run it without all six though. I generally have too many other problems to put things like that at risk that can generally be fixed w/o much problem.
Re: Broke off bolt in crank pully? Is that OK to leave? [Re: Chilort] #513163
11/02/09 11:45 AM
11/02/09 11:45 AM
PA
70Duster Offline
70Duster  Offline
PA
If you can't spin it out with the tip of your finger, this may be an ideal application for a left handed drill bit.
Re: Broke off bolt in crank pully? Is that OK to leave? [Re: 70Duster] #513164
11/02/09 04:11 PM
11/02/09 04:11 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Can you just let it go?
Depends on who you are. If I just let it go, it would come back and haunt me. You probably have better luck.
Re: Broke off bolt in crank pully? Is that OK to leave? [Re: CYACOP] #513165
11/02/09 04:26 PM
11/02/09 04:26 PM
IL
mopar addict
mopar addict
IL
Thanks for all your help! I was able to use a small screwdriver to turn out the broken end.
