Block repair #512880
11/01/09 07:50 AM
11/01/09 07:50 AM
Kent,OH
B&E Offline OP
B&E  Offline OP
Kent,OH
I have a 383 that is cracked in the valley area above the two inside lifter bores.Since it is a water passage is there any epoxy type product that will seal it?I had it welded with no luck.
Thanks,Dave
68 Super Bee Black,White stripe
Re: Block repair [Re: B&E] #512881
11/01/09 09:02 AM
11/01/09 09:02 AM
Sarnia, Ontario, Canada
W
whydana Offline
whydana  Offline
W
Sperry Welding in Capac, Michigan, 810-395-4381
He doesn't use nickel based rods. He does it the old fashioned way, like brazing. Excellent work. Good luck.
Re: Block repair [Re: whydana] #512882
11/01/09 11:20 AM
11/01/09 11:20 AM
I would think that if welding didn't do it that epoxy certainly would not but I think it takes as said brazing which brazing cast iron requires the metal to be heated cherry red (to some point). My guy did my completely broken 340 HP ex manifolds that everybody said were useless. Havent used them yet but they look good
Re: Block repair [Re: RapidRobert] #512883
11/01/09 11:52 AM
11/01/09 11:52 AM
Kent,OH
B&E Offline OP
B&E  Offline OP
Kent,OH
I am just looking for an alternative to welding.I thought that in the hi-tech world we live in there could be some product out there that would seal it.I know it isn't likely.
Re: Block repair [Re: B&E] #512884
11/01/09 01:59 PM
11/01/09 01:59 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
I would just replace the block.
Re: Block repair [Re: CYACOP] #512885
11/01/09 02:06 PM
11/01/09 02:06 PM
Kirkland, Washington
Pacnorthcuda Offline
Yep... Welding MAY work but unless its a numbers block to a rare car that sounds like scrap. Epoxy is unlikely to work due to thermal expansion of the block--HIGHLY likely to crack. You would constantly be looking for coolant in oil, until you found it of course.
Re: Block repair [Re: B&E] #512886
11/01/09 03:08 PM
11/01/09 03:08 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
http://www.locknstitch.com/CylinderHeadRepairs.htm
Check out about cast iron welding and alternatives
Re: Block repair [Re: DZJim] #512887
11/01/09 06:16 PM
11/01/09 06:16 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
I went and visited them since they're nearby me.
They do good very work but after my experience, I would get whatever part you need repairing magnafluxed by a very good shop first. Felt pen in any small hard to see cracks up front before giving them the work. They missed one on mine but we caught it later.
Here's a pic of a Hemi block they were planning on repairing.
Re: Block repair [Re: Topcat] #512888
11/01/09 09:21 PM
11/01/09 09:21 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Don't know who did it or how this head was fixed but it appears to have been welded. Someone did a very nice job on it, didn't even know it was there 'till I had 'em surfaced. I've had them on three different combos so far and not asingle problem.
Re: Block repair [Re: Bill MeLater] #512889
11/01/09 09:55 PM
11/01/09 09:55 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
This stuff might work. Has the same thermal expansion rates as steel. Used it on a 428 with a crack in the valley. Prep work has to be done properly, grind the surface and use acetone or brake clean.
Also works good on intake ports if you get a little greedy...
http://www.devcon.com/products/products.cfm?brandid=1&familyid=101
