91 A-518 Drain back, where is it located #511735
10/30/09 06:19 PM
10/30/09 06:19 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
Got a problem with a 91 dodge van with an A518 (350)
any way it takes a moment (a few min or so) for the transmission to engage once in gear.
Kinda like the trans is empty on fluid..
but the fluid is full
could it be
The TC drain back/front pump?
a clogged filter?
VB problems?
or could it be something else?
If its the TC/drain back or front pump approx what would a shop charge to fix it?
thanks
Re: 91 A-518 TRANSMISSION problems [Re: Dakota_Don] #511736
10/30/09 06:23 PM
10/30/09 06:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Does this happen when you first drive it or all the time? If it's the first thing after sitting over night try letting it idle in neutral for a few seconds before going in gear.
Re: 91 A-518 TRANSMISSION problems [Re: stumpy] #511737
10/30/09 06:27 PM
10/30/09 06:27 PM
Alton, IL
Alton, IL
yes it happens when it it sits a while.. it has to run a min in netral before engageing into gear..
Re: 91 A-518 TRANSMISSION problems [Re: Dakota_Don] #511738
10/30/09 06:30 PM
10/30/09 06:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried changing the fluid and filter?
Re: 91 A-518 TRANSMISSION problems [Re: stumpy] #511739
10/30/09 06:39 PM
10/30/09 06:39 PM
Alton, IL
Alton, IL
NOT YET, sopposedly it was flushed.. But the filter could be clogged.. I also would think it would have other plroblems if the filter was clogged.. draining it now..
Re: 91 A-518 TRANSMISSION problems [Re: Dakota_Don] #511740
10/30/09 06:52 PM
10/30/09 06:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think it takes ATF+4.
Re: 91 A-518 TRANSMISSION problems [Re: stumpy] #511741
10/30/09 07:06 PM
10/30/09 07:06 PM
Alton, IL
Alton, IL
thats what i have.. the filter looks pretty good.. i have seen worse..
Re: 91 A-518 TRANSMISSION problems [Re: Dakota_Don] #511742
10/30/09 07:39 PM
10/30/09 07:39 PM
Alton, IL
Alton, IL
I remember some yrs ago, dad had a simular problem with a 727.. and I thought he said it was a valve , (drain back) i think, it was letting the TC drain back.. there-fore every time he started it it had to re-fill and pump up.. But I looked in my 518 atsg manual and can not find such a thing.
Re: 91 A-518 TRANSMISSION problems [Re: Dakota_Don] #511743
10/30/09 10:37 PM
10/30/09 10:37 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
I recall reading something about newer rigs having an anti-drainback valve in the line to the radiator/cooler to prevent that from happening.
What would happen is that valve would get plugged, and cook the transmission in short order
Sitting in neutral for a little bit is an easy fix.
Re: 91 A-518 TRANSMISSION problems [Re: hooziewhatsit] #511744
10/31/09 07:41 PM
10/31/09 07:41 PM
Alton, IL
Alton, IL
I think that was 93 or 95 and up..
