I recall reading something about newer rigs having an anti-drainback valve in the line to the radiator/cooler to prevent that from happening.
What would happen is that valve would get plugged, and cook the transmission in short order
Sitting in neutral for a little bit is an easy fix.
If you ever find yourself in a fair fight, your tactics suck.
