Is this carb on backwards? #511384
10/30/09 10:19 AM
10/30/09 10:19 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Or am I just having a bad day with the memory...(its not mine)
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Is this carb on backwards? [Re: Pyper70] #511385
10/30/09 10:25 AM
10/30/09 10:25 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Somebody is having some serious linkage problems...
Re: Is this carb on backwards? [Re: Pyper70] #511386
10/30/09 10:28 AM
10/30/09 10:28 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Mind this is going in a 1968 Charger, 440/ 727....I think those are A-Body linkage but it looks like I am staring at the passenger side #2 cylinder with the throttle linkage over it....
Re: Is this carb on backwards? [Re: Pyper70] #511387
10/30/09 10:30 AM
10/30/09 10:30 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
That looks like the kickdown linkage for a A body.
Re: Is this carb on backwards? [Re: dmerc] #511388
10/30/09 10:40 AM
10/30/09 10:40 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Large vacuum inlet is normally in the rear of the manifold so that does look right.
Re: Is this carb on backwards? [Re: stumpy] #511389
10/30/09 10:43 AM
10/30/09 10:43 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
For some reason the runners look longer to the right side of the picture...
Re: Is this carb on backwards? [Re: Pyper70] #511390
10/30/09 10:45 AM
10/30/09 10:45 AM
Grand Prairie,Texas
Grand Prairie,Texas
May just be the angle it was taken from. It's not sitting on the table straight.
Re: Is this carb on backwards? [Re: stumpy] #511391
10/30/09 11:05 AM
10/30/09 11:05 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
At 1st. it looked backwards, but now i see the large vacuum port so its on right, whats up with that linkage?
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Is this carb on backwards? [Re: Pyper70] #511392
10/30/09 11:20 AM
10/30/09 11:20 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
If you think it don't look right now, wait till you flip it around and see how it looks backwards. (the manifold). It's on right, you'll have to maybe do the locar thing.
Re: Is this carb on backwards? [Re: buildanother] #511393
10/30/09 03:28 PM
10/30/09 03:28 PM
Commando1 Offline
Commando1  Offline
Look closely at a correct setup"
Re: Is this carb on backwards? [Re: Pyper70] #511394
10/30/09 03:44 PM
10/30/09 03:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No it's installed in the correct position , the manifold doesn't really care if the vac port is in the front or the rear .
The linkage is NOT A body anything , that's a 72 up 1 piece setup and it's NEVER going to work properly, nevermind it's missing the mpar throttle adaptor and that angle for the throttle cable is going to cause issues .
It's needs Andyf's hise rise throttle adapter bracket to correct the throttle cable angle, the mopar linkage adapter and a bouchilion throttle valve linkage cable to the carb because the one piece setup is not going to work with that manifold .
Re: Is this carb on backwards? [Re: JohnRR] #511395
10/30/09 04:13 PM
10/30/09 04:13 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Oh no I understand fully...Like I said its not mine. Mine has the working kickdown linkage. I make my own stuff like my throttle brackets for my Lokar and they always work like a charm. I am trying to help this guy out fix his car but he is on the fence. I tell him how to do it but he never does it, doesnt even own a set of SAE wrenches...Always expecting others to do it for him. I am part of a small local club here with maybe 25 cars and he has a Gen Lee and is restoring it. I just like pointing out the incorrect things he has bought to him. He trusts some 50 yr old mechanic that has never owned anything American except magazines. He trusts his opinion more than mine. I have never opened my hood for any of these guys and they are convinced my 69 R/T has a slant 6 under it.
Re: Is this carb on backwards? [Re: Pyper70] #511396
10/30/09 06:17 PM
10/30/09 06:17 PM
Grand Prairie,Texas
Grand Prairie,Texas
Then don't worry about it. Let the owner learn from his mistakes just like the rest of us.
Re: Is this carb on backwards? [Re: stumpy] #511397
10/30/09 06:27 PM
10/30/09 06:27 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I just like having the answer at my disposal when he approaches me to fix it for him. I'll make sure to charge him extra special for it.
Re: Is this carb on backwards? [Re: stumpy] #511398
10/30/09 06:28 PM
10/30/09 06:28 PM
usa
Mopar1970440 Offline
usa
Linkage is odd and problaby wont work good at all..and his transmission is going to burn up.
Re: Is this carb on backwards? [Re: Mopar1970440] #511399
10/30/09 08:09 PM
10/30/09 08:09 PM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
Only if it's an auto!
Re: Is this carb on backwards? [Re: I go fast] #511400
10/31/09 08:37 AM
10/31/09 08:37 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
well if you know what you are looking at in that picture the linkage shown is the THROTTLE VALVE LINKAGE for an AUTOMATIC TRANS ...
Re: Is this carb on backwards? [Re: JohnRR] #511401
10/31/09 08:41 AM
10/31/09 08:41 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Well its a 727....but on my setup 440/727 again, I have the carb adapter hooked up to the throttle cable correctly. I didnt take the picture. I am just puzzled by wanna be mechanics....This is the same mechanic who installed his alternator on right in front of his fuel pump...an inch away from his subframe to "clean up the engine bay"....
Now the guy who is assembling this car is saying he took it from a 73 Charger with a 318...I still don't think he has a kickdown linkage. Its going to be funny when he finds his transmission all over the street here.
Re: Is this carb on backwards? [Re: JohnRR] #511402
10/31/09 08:43 AM
10/31/09 08:43 AM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
And John,if you look again it is connected as throttle linkage and would work as such but not well.
Re: Is this carb on backwards? [Re: I go fast] #511403
10/31/09 11:28 AM
10/31/09 11:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Linkage is odd and probably wont work good at all..and his transmission is going to burn up.
Please look again , the factory throttle cable is installed on the linkage in board of the trans linkage. But you are correct if that mess was being used a throttle linkage it would not work well at all .
