Source heads #509621
10/28/09 01:42 AM
10/28/09 01:42 AM
Fitchbug, Mass.
WannaRunner Offline OP
Fitchbug, Mass.
Will the CNC'ed 440source heads that modern is doing flow enough for a 512 or 528 stroker?? this would be with the Airgap dual quad intake and QF E85 carbs.
Re: Source heads [Re: WannaRunner] #509622
10/28/09 01:45 AM
10/28/09 01:45 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
How much power do you want? The general rule of thumb is 2hp per cfm of flow. By that token the CNC'd source heads should do over 600hp.
Re: Source heads [Re: DaytonaTurbo] #509623
10/28/09 02:54 AM
10/28/09 02:54 AM
Fitchbug, Mass.
Fitchbug, Mass.
Thats about what I'm looking for, i want it to be streetable.....
Re: Source heads [Re: WannaRunner] #509624
10/28/09 05:15 AM
10/28/09 05:15 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Might want to try posting on the racers forum. A few guys there have the heads and have done similar mods with them.
Re: Source heads [Re: migsBIG] #509625
10/28/09 09:13 AM
10/28/09 09:13 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Depends of what you want. Flow is one thing, crossectional area is another. If you have cubes and you want power, you'll need a proper port size. The CNC 440source head is very good for a big high torq engine, but the port size will hold it back at higher rpm.
Plynouth VIP '67 TT IC EFI
Re: Source heads [Re: jyrki] #509626
10/28/09 03:46 PM
10/28/09 03:46 PM
Fitchbug, Mass.
Fitchbug, Mass.
I'm not worried so much about high RPM use as I will only go to the track once in a great while, I'm looking more at low end "grunt" for in town driving...
Thanks for the heads up guys.....
Re: Source heads [Re: WannaRunner] #509627
10/28/09 08:22 PM
10/28/09 08:22 PM
Ohio
I
iron6 Offline
iron6  Offline
I
Ohio
I have a set still in the box I'll sell for $900.00 you pay the shipping. I changed my mind and plan to use an INDY EZ. Call 717-514-1216
Re: Source heads [Re: iron6] #509628
10/28/09 09:26 PM
10/28/09 09:26 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
Where were you 6 months ago?
Re: Source heads [Re: 1fastrunner] #509629
10/28/09 11:52 PM
10/28/09 11:52 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
my honest first hand advice is to save your money and buy eddie cnc heads. the source heads arent the best quality castings. i have more into my source heads fixing quality control issues than a set of eddies are worth.
Re: Source heads [Re: chrisf] #509630
10/29/09 01:23 AM
10/29/09 01:23 AM
Fitchbug, Mass.
Fitchbug, Mass.
Is everything in the stock location with the Eddies?
~thanks
Re: Source heads [Re: WannaRunner] #509631
10/29/09 03:10 AM
10/29/09 03:10 AM
Manitoba, Canada
Manitoba, Canada
~thanks
Yes.
FWIW I had zero problems with my source heads out of the box and I've been daily driving them. Plus the CNC'd source heads are done by modern cylinder head so they do get looked over again before you get them.
Re: Source heads [Re: DaytonaTurbo] #509632
10/29/09 03:48 AM
10/29/09 03:48 AM
Fitchbug, Mass.
Fitchbug, Mass.
~thanks
Yes.
Thanks!
Re: Source heads [Re: DaytonaTurbo] #509633
10/29/09 08:08 AM
10/29/09 08:08 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
~thanks
Yes.
Did Edelbrock change the sparkplug angles back to stock angles at one time?
I thought only the Mopar Performance heads made by Edelbrock had at least the sparkplugs at 90 degrees to the head again.
Re: Source heads [Re: BigBlockMopar] #509634
10/29/09 08:50 AM
10/29/09 08:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
E heads use angle plugs.I also have the Sourve heads and have about 400 into new spreings retainers keepers.Id of had to change them on the E heads also.I have over 2 years on my heads street and strip.No problems at all.Mine are the first ones.If they had had the CNC ones I would have bought them.Rocky
Chrysler Firepower
Re: Source heads [Re: therocks] #509635
10/29/09 09:45 AM
10/29/09 09:45 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I ran the numbers for the ported Source heads on desktop dyno and they made more torque and HP than ez1 heads. This was with a mild solid roller and with the 512 and 528 configuration. However, they are at their limit at that point so if you want more power in the future then you have to go with a different head.
For what you're doing I'd go with the 512 and the ported Source heads. They don't need any special rockers, etc.
Re: Source heads [Re: Stanton] #509636
10/29/09 07:14 PM
10/29/09 07:14 PM
Fitchbug, Mass.
Fitchbug, Mass.
Thanks for your effort! the 512 is about where I am hovering, anything more and the RR will be on skates.....
