Re: Source heads
[Re: migsBIG]
#509625
10/28/09 09:13 AM
10/28/09 09:13 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
Depends of what you want. Flow is one thing, crossectional area is another. If you have cubes and you want power, you'll need a proper port size. The CNC 440source head is very good for a big high torq engine, but the port size will hold it back at higher rpm.
Plynouth VIP '67 TT IC EFI
Re: Source heads
[Re: WannaRunner]
#509631
10/29/09 03:10 AM
10/29/09 03:10 AM
DaytonaTurbo
Manitoba, Canada
Is everything in the stock location with the Eddies?
~thanks
Yes.
FWIW I had zero problems with my source heads out of the box and I've been daily driving them. Plus the CNC'd source heads are done by modern cylinder head so they do get looked over again before you get them.
Re: Source heads
[Re: DaytonaTurbo]
#509632
10/29/09 03:48 AM
10/29/09 03:48 AM
Posts: 299 Fitchbug, Mass.
WannaRunner
Fitchbug, Mass.
~thanks
Yes.
Thanks!
Re: Source heads
[Re: DaytonaTurbo]
#509633
10/29/09 08:08 AM
10/29/09 08:08 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
~thanks
Yes. ...
Did Edelbrock change the sparkplug angles back to stock angles at one time?
I thought only the Mopar Performance heads made by Edelbrock had at least the sparkplugs at 90 degrees to the head again.
Re: Source heads
[Re: BigBlockMopar]
#509634
10/29/09 08:50 AM
10/29/09 08:50 AM
Posts: 21,064 Niles , Ohio
therocks
Niles , Ohio
E heads use angle plugs.I also have the Sourve heads and have about 400 into new spreings retainers keepers.Id of had to change them on the E heads also.I have over 2 years on my heads street and strip.No problems at all.Mine are the first ones.If they had had the CNC ones I would have bought them.Rocky
Chrysler Firepower
Re: Source heads
[Re: Stanton]
#509636
10/29/09 07:14 PM
10/29/09 07:14 PM
WannaRunner
Fitchbug, Mass.
I ran the numbers for the ported Source heads on desktop dyno and they made more torque and HP than ez1 heads. This was with a mild solid roller and with the 512 and 528 configuration. However, they are at their limit at that point so if you want more power in the future then you have to go with a different head.
For what you're doing I'd go with the 512 and the ported Source heads. They don't need any special rockers, etc.
Thanks for your effort! the 512 is about where I am hovering, anything more and the RR will be on skates.....
