1966 VIN locations?
#50959
12/24/07 11:08 PM
12/24/07 11:08 PM
Posts: 584 Los Angeles, CA
Freiburger
Los Angeles, CA
I just got a '66 Satellite with the dash cut out and long gone, so there's no VIN there. One VIN tag is still in the driver's door jamb. I can't seem to spot a number on the core support. In '66 did they stamp the VIN anywhere else on the car?
Facebook.com/DavidFreiburger
70 Super Bee - 68 Charger - 68 Dart
75 Gremmie and 20-plus other junkers
Re: 1966 VIN locations?
[Re: RUNCHARGER]
#50962
12/24/07 11:39 PM
12/24/07 11:39 PM
Freiburger
Los Angeles, CA
Thanks for the info. Looks like I'm stuck with one VIN tag. At least it has original rivets.
[Re: Freiburger]
#50964
12/24/07 11:41 PM
12/24/07 11:41 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
My old '66 Satellite only had the one on the pillar from memory..and it had been a one owner car as well. (did sell it some years back though,so going from what I can remember )
[Re: Freiburger]
#50966
12/25/07 12:04 AM
12/25/07 12:04 AM
Posts: 2,886 US of A
A38s!
US of A
Not quite 'on the body', but the Certicard's a spot.
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
[Re: 69CoronetRT]
#50968
12/25/07 09:35 AM
12/25/07 09:35 AM
RapidRobert
66 VIN is only on the door post. Sales Order numbers are on the tag, radiator support and behind the back bumper.
Doug what "tag" are you refering to?
[Re: Gary67]
#50970
12/25/07 10:19 AM
12/25/07 10:19 AM
RapidRobert
OK the shipping order number is on the fender tag on the inner fender in the engine bay. Now I got it. Thanks gary. RR
[Re: 05dakota]
#50973
12/26/07 12:36 PM
12/26/07 12:36 PM
Freiburger
Los Angeles, CA
Really helpful info, everyone. Thanks. I only had a '64 once, so this '66 is the first time I've paid attention to this stuff on a pre-'68 Mopar.
[Re: ddartdude]
#50976
12/28/08 12:25 AM
12/28/08 12:25 AM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
David, are you looking into your Mohave Green car? For cars '67 and older, you can get an IBM card that is the Build record of the car from Chrysler historical. The card will have the VIN and the S.O. number on it. If you can locate the SO#'s on the body, the IBM card ties them together to prove the cars VIN. The SO numbers can be hard to find. You need to have the rear bumper off and look near where the left bumper bracket mounts to the body. On the core support it is near the top left corner of the radiator. It could be on the front, back, or on top of the core support. Chysler historical can be contacted at: pms@chrysler.comGood luck!
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#50977
12/28/08 12:59 AM
12/28/08 12:59 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Good luck!
Joel Nailed it! Here's where to look for the rear number
[Re: ScottSmith_Harms]
#50978
12/28/08 09:34 AM
12/28/08 09:34 AM
Posts: 2,234 BFE
vancamp
super street
super street
BFE
like some have said it is hit and miss if the S.O. numbers are stamped my 66 Satellite does not have the core support or the the rear bumper brace stampings, I seen cars with none, both or only one. vin,fendertag and certicard are really the only numbers you can rely on when looking at a 66 other than date codes.
VanCamp Dent Systems
Paintless Dent Repair/
Mopar Restification
