thermostat #509241
10/27/09 08:53 PM
10/27/09 08:53 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
...chasing a pesky thermostat housing leak.Got everything buttoned up and wondered what would happen if the thermostat is installed upside down?
Would it still work but cycle at a higher temp or maybe overheat?
Anybody? ......... al
Re: thermostat [Re: can.al] #509242
10/27/09 09:32 PM
10/27/09 09:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
won't work because the part that causes the thermostat to open won't get hot. It would over heat.
Re: thermostat [Re: stumpy] #509243
10/27/09 09:40 PM
10/27/09 09:40 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..thanks Stumpy.Pretty sure I checked this.
Used a bit of silicon and will start it tomorrow.Guess I'll watch my gauge and and keep checking my upper rad hose w/my hand.
I thought that the hot water on the wrong side would eventually heat it enough to open it a bit....al
Re: thermostat [Re: can.al] #509244
10/28/09 12:23 AM
10/28/09 12:23 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
What kind of housing - chrome big block one by any chance? They're known to leak.
Ride eternal, shiny and chrome
Re: thermostat [Re: DirectSubjection] #509245
10/28/09 08:43 AM
10/28/09 08:43 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Always surface the housing before installing.
logan426
Re: thermostat [Re: DirectSubjection] #509246
10/28/09 09:17 AM
10/28/09 09:17 AM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
...not chrome,alum for smallblock.Saw a few cast iron ones at Carlisle....should have bought one.
Anyway started it and let it warm up about 20 minues ago and cooling system cycled O.K.
It would usually seep a bit after it cooled down.I'll check it later.....tx all
..al
'Old Earl use to say you can dress a "10" in rags.....she'll still be a 10!
