Re: Truck 440 cam selection help...
[Re: mark7171]
#508795
10/27/09 09:37 PM
10/27/09 09:37 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Would an Edelbrock Performer intake work well with this combination?
Yes, Probably a better manifold. Performers are higher rise and have slightly higher torque points. the performer is 4"+'s tall the weiand is like 3 1/2.
I would change the old springs, and seals on the old stock head.
Thanks. That makes me happy, because a performer is what I've got
Seals will be replaced as part of the entire gasket kit I'll be purchasing from summit/440source. Haven't decided on that one yet.
[Re: Pat_Whalen]
#508797
10/27/09 09:44 PM
10/27/09 09:44 PM
DaytonaTurbo
Manitoba, Canada
I believe both of us have very different goals for our trucks
I agree. For a 2wd street bruizer of a truck, the whiplash seems like it'd be a good choice. For an off-roader a milder cam is good.
Pat, I'm going to say your stock valve springs are probably going to be okay. This cam is similar in spec to the stock HP cam, and the HP 440's did get different valve springs than stock. However the lift is low and duration is mild. You're not going to get crazy high rpms out of it.
[Re: PowerWagonDude]
#508800
10/27/09 11:07 PM
10/27/09 11:07 PM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
You can get a resto magnum purple stick through Summit for under $180 w/lifters. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
[Re: Neil]
#508802
10/28/09 12:15 AM
10/28/09 12:15 AM
Pat_Whalen
super gas
super gas
Mesa, AZ
I'm honestly considering the summit 6400. My only reservations are not knowing if my stock valve springs can hold up to it, and not knowing what stall converter I'm running to make sure it's appropriate.
I did take a look at the PAW cam. Seems fairly close in relation to the summit cam. Like I said, without sacrificing drivability, vacuum, and lifespan, would the summit produce the same amount of power just at a slightly higher RPM? I do a lot of highway driving, so I wouldn't mind the 2000-4500 rpm range, but I'd also like to be able to get moving from stop light to stop light, if you know what I mean.
[Re: phantomx]
#508804
10/28/09 01:21 AM
10/28/09 01:21 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Why buy a stock mopar cam grind when there are cams with more modern designs that will perform better?
Get something with a wide lobe seperation angle to keep the idle smooth.
. The resto cam also has a 115deg lsa, so it should idle like...well kinda stock
You don't say?
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: R70RUNNER]
#508805
10/28/09 10:10 AM
10/28/09 10:10 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I ran the small Summit cam in my 446 cid. I really haven't had a chance to run it, other that it idles well with open headers in my 86 RC.
Moparlee
[Re: phantomx]
#508809
10/28/09 10:02 PM
10/28/09 10:02 PM
R70RUNNER
Riverside, Ca
You don't say?
I do, I do... Travis..
