Re: Truck 440 cam selection help... [Re: Pat_Whalen] #508794
10/27/09 08:43 PM
10/27/09 08:43 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
[quote
Would an Edelbrock Performer intake work well with this combination?
Yes, Probably a better manifold. Performers are higher rise and have slightly higher torque points. the performer is 4"+'s tall the weiand is like 3 1/2.
I would change the old springs, and seals on the old stock head.
Re: Truck 440 cam selection help... [Re: mark7171] #508795
10/27/09 09:37 PM
10/27/09 09:37 PM
Mesa, AZ
P
Pat_Whalen Offline OP
super gas
super gas
P
Mesa, AZ
Thanks. That makes me happy, because a performer is what I've got
Seals will be replaced as part of the entire gasket kit I'll be purchasing from summit/440source. Haven't decided on that one yet.
Re: Truck 440 cam selection help... [Re: mark7171] #508796
10/27/09 09:43 PM
10/27/09 09:43 PM
Seattle Wa
PowerWagonDude Offline
Seattle Wa
I have used Summits cam 6401(224@.050/.465 lift) in a 68 440 and 400s. It works good in a high compression 440 but is lopey. In a 400 it had good topend but no low end guts. I prefer PAW cam 22942- Pawengineparts dot com...
It has 204/214@.050/.420/.443 lift. It was a great truck cam in my 85 3/4 ton. Better mileage by far than 6401 and much more low rpm power. I think it would work good in a low compression 440. The PAW cams are cheap and good quality. I always use their lifters and valve springs also. I would use that cam with an Iron spread bore intake, a 1/2" spread bore to square hole adapter and a Holley 600 or a 750 #3310.
Re: Truck 440 cam selection help... [Re: Pat_Whalen] #508797
10/27/09 09:44 PM
10/27/09 09:44 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I believe both of us have very different goals for our trucks
I agree. For a 2wd street bruizer of a truck, the whiplash seems like it'd be a good choice. For an off-roader a milder cam is good.
Pat, I'm going to say your stock valve springs are probably going to be okay. This cam is similar in spec to the stock HP cam, and the HP 440's did get different valve springs than stock. However the lift is low and duration is mild. You're not going to get crazy high rpms out of it.
Re: Truck 440 cam selection help... [Re: Pat_Whalen] #508798
10/27/09 09:58 PM
10/27/09 09:58 PM
Indiana, United Staes, Vevay
LikarockCrusher Offline
As the valve springs go check with Manufacturer on the height open. And Closed pounds. And if your springs are in good shape they probably good to go.
Re: Truck 440 cam selection help... [Re: LikarockCrusher] #508799
10/27/09 10:14 PM
10/27/09 10:14 PM
Seattle Wa
Seattle Wa
the PAW cam I recommended requires a spring with seat pressure of 100 lbs. and open pressure of 265 lbs. I have used it with stock valve springs. If you decide to use the Summit cam #6400 then make sure you have the high stall torque converter(fat ring gear). The PAW cam is rated 1500-4000 RPM. The Summit cam #6400 is 2000-4500 RPM. I guess the choice depends on what RPM range you do most of your driving
Re: Truck 440 cam selection help... [Re: PowerWagonDude] #508800
10/27/09 11:07 PM
10/27/09 11:07 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
You can get a resto magnum purple stick through Summit for under $180 w/lifters.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: Truck 440 cam selection help... [Re: phantomx] #508801
10/27/09 11:18 PM
10/27/09 11:18 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have a small lunati voodoo cam in the 400 sbc that powers my daily beater pickup. Pulls good vacume, idles smooth, and it's very responsive. Why buy a stock mopar cam grind when there are cams with more modern designs that will perform better?
Get something with a wide lobe seperation angle to keep the idle smooth.
Re: Truck 440 cam selection help... [Re: Neil] #508802
10/28/09 12:15 AM
10/28/09 12:15 AM
Mesa, AZ
P
super gas
super gas
P
Mesa, AZ
I'm honestly considering the summit 6400. My only reservations are not knowing if my stock valve springs can hold up to it, and not knowing what stall converter I'm running to make sure it's appropriate.
I did take a look at the PAW cam. Seems fairly close in relation to the summit cam. Like I said, without sacrificing drivability, vacuum, and lifespan, would the summit produce the same amount of power just at a slightly higher RPM? I do a lot of highway driving, so I wouldn't mind the 2000-4500 rpm range, but I'd also like to be able to get moving from stop light to stop light, if you know what I mean.
Re: Truck 440 cam selection help... [Re: Neil] #508803
10/28/09 12:58 AM
10/28/09 12:58 AM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
The mopar cams (even the old ones) have pretty fast lift rates. Compare advertised vs .050 duration numbers with other cheap cams and you'll see the mopar cams have bigger .050 numbers for a given advertised number. The resto cam also has a 115deg lsa, so it should idle like...well kinda stock
Travis..
Re: Truck 440 cam selection help... [Re: phantomx] #508804
10/28/09 01:21 AM
10/28/09 01:21 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
You don't say?
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Truck 440 cam selection help... [Re: R70RUNNER] #508805
10/28/09 10:10 AM
10/28/09 10:10 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I ran the small Summit cam in my 446 cid. I really haven't had a chance to run it, other that it idles well with open headers in my 86 RC.
Moparlee
Re: Truck 440 cam selection help... [Re: PowerWagonDude] #508806
10/28/09 10:16 AM
10/28/09 10:16 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Wow is this what you got your 440 in?
Moparlee
Re: Truck 440 cam selection help... [Re: R70RUNNER] #508807
10/28/09 08:33 PM
10/28/09 08:33 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
You don't say?
I do, I do...
Travis..
Re: Truck 440 cam selection help... [Re: Robbins] #508808
10/28/09 09:01 PM
10/28/09 09:01 PM
Seattle Wa
Seattle Wa
No thats not my 440 truck. That is my good gas mileage rig. It has a slant six with a granny low four speed
Re: Truck 440 cam selection help... [Re: phantomx] #508809
10/28/09 10:02 PM
10/28/09 10:02 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
You don't say?
I do, I do...
Travis..
Re: Truck 440 cam selection help... [Re: Pat_Whalen] #508810
11/03/09 02:22 PM
11/03/09 02:22 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
Check out the Hughes line of camshafts. They have some with short duration but they still have some pretty good lift to them.
Re: Truck 440 cam selection help... [Re: RalleyA12] #508811
11/03/09 08:25 PM
11/03/09 08:25 PM
Grand Rapids, MI
11secondC Offline
11secondC  Offline
Grand Rapids, MI
I ran the 6400 summit cam in my '67 VIP with a rering/rebearing 413 years ago. Other than headers motor was stock. Could barely tell it had any lope to it, ran out of breath at 5k, but would melt the right tire off even with the 2.76's from a dead punch.
