PerTronix's Ignitor ignition system? #508697
10/27/09 10:36 AM
10/27/09 10:36 AM
NE
moparpoolman Offline OP
NE
Any one convert from points to one of these PerTronix systems? Do they work good? Thinking of trying so I don't have to mount an ECU box and never to have to deal with points again. Like to hear some input first, Thanxs.
Re: PerTronix's Ignitor ignition system? [Re: moparpoolman] #508698
10/27/09 10:39 AM
10/27/09 10:39 AM
MoreParts Offline
MoreParts  Offline
I've been using one since '96 on my Challenger. Works great! I converted my Pontiac with the II version about 5 years ago, and works even better.
Re: PerTronix's Ignitor ignition system? [Re: MoreParts] #508699
10/27/09 10:41 AM
10/27/09 10:41 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Put one in the kids 67 Chrysler.Worked great and easy setup.Rocky
Chrysler Firepower
Re: PerTronix's Ignitor ignition system? [Re: therocks] #508700
10/27/09 10:52 AM
10/27/09 10:52 AM
MD
floyd Offline
floyd  Offline
MD
Do people use stock coils, or the "flame-thrower"? I've been thinking about converting, but I want to keep the OEM look and would prefer to use my Mopar coil.
Re: PerTronix's Ignitor ignition system? [Re: floyd] #508701
10/27/09 10:57 AM
10/27/09 10:57 AM
MoreParts Offline
MoreParts  Offline
You can use either coil, but I chose to go with their black restoration look coil for my rides.
Re: PerTronix's Ignitor ignition system? [Re: MoreParts] #508702
10/27/09 12:54 PM
10/27/09 12:54 PM
scratchnfotraction Offline
15 yrs with a 40.000 volt flame thrower coil
got about 4 of them in use now..
make sure to use only there rotor button,other ones dont fit as good and can cause problems
I am useing there rotor on the 15 yr old one after changing it...its got 14 yrs on that rotor and no trouble
tune up is cap and wires with plugs
Re: PerTronix's Ignitor ignition system? [Re: moparpoolman] #508703
10/27/09 02:31 PM
10/27/09 02:31 PM
new jersey
mr.rt Offline
mr.rt  Offline
new jersey
I have been using an ignitor one for 3 years now, no trouble am also using the flamethrower 1.5 ohm coil with a ballast resistor. For a stock look I bypassed the ballast resistor by cutting out the ciol in the back & solderer a wire to the two prongs & pluged in the stock wiring for that stock look.
Re: PerTronix's Ignitor ignition system? [Re: mr.rt] #508704
10/27/09 03:02 PM
10/27/09 03:02 PM
yes I did the BR bypass also on mine to give a full 12 volts to it
I used a #10 stranded wire and solderd the end and reused the porcilin shell
from the dist the red wire hooks to positive side of coil with keyd hot wire from harness
black wire fron dist to negitive side of coil
very easy and simple conversion,all hiddin under the cap
the red and black wires are the give away to some one that knows what to look for
best $79.00 I spent on the 68 Dart
Re: PerTronix's Ignitor ignition system? [Re: moparpoolman] #508705
10/27/09 05:01 PM
10/27/09 05:01 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
I been using my ignitor II and coil for about a month, its much better then points.. but i am on my second unit the first ran fine, then the next day wouldnt start no fire.. had to order another unit, somehow the module failed...if i do it again it will be a MP factory unit.
Re: PerTronix's Ignitor ignition system? [Re: Dakota_Don] #508706
10/27/09 07:15 PM
10/27/09 07:15 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I am using the pertronix billet distributor and black coil on my 67 440 motor.. Nice and clean and EASY to install.....
Re: PerTronix's Ignitor ignition system? [Re: Dakota_Don] #508707
10/27/09 07:48 PM
10/27/09 07:48 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
If you leave/ left the key in the run position for more than 20 seconds/overnight you run the risk of burning up the module.
Re: PerTronix's Ignitor ignition system? [Re: 64Post] #508708
10/27/09 09:29 PM
10/27/09 09:29 PM
MA
440beeper Offline
440beeper  Offline
MA
easy install and works great .
