Is a heated rod (spun bearing) junk once its heated? #507526
10/25/09 10:47 PM
10/25/09 10:47 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
My friends engine spun a rod bearing.
That made the rod get hot and it got some heat coloring due to the fact that it soun a bearing.
Is it OK to reuse that rod or once its been heated to the point of seeing a color change on the surface, is it JUNK?
Re: Is a heated rod (spun bearing) junk once its heated? [Re: domingo] #507527
10/25/09 10:50 PM
10/25/09 10:50 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
I would junk it. Not worth reusing in my opinion. A guy that I know that reconditions rods says no problem. I say they are good for someone other than me.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Is a heated rod (spun bearing) junk once its heated? [Re: domingo] #507528
10/25/09 11:44 PM
10/25/09 11:44 PM
How much heat coloring and what kind of rod, steel or alumimum,stock, Eagle or? I agree with Sloan, throw the two bad ones(the one next to it also) away and get good ones now to avoid catastroshic failure later
Re: Is a heated rod (spun bearing) junk once its heated? [Re: domingo] #507529
10/26/09 07:40 AM
10/26/09 07:40 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes, it's junk.
Re: Is a heated rod (spun bearing) junk once its heated? [Re: Challenger 1] #507530
10/26/09 11:38 AM
10/26/09 11:38 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Childs & Albert H beams.
Yes I told my buddy I didnt know for sure, but if it were me, Id scrap them.
Re: Is a heated rod (spun bearing) junk once its heated? [Re: domingo] #507531
10/26/09 11:56 AM
10/26/09 11:56 AM
I have reused street Hemi rods when I first started racing that had spun a bearing inside the rod but not overlap them and did not turn the crank and rods black they did have minor heat discoloring but not severe The big things is to have them magged first and then how much shorter can you stand for the two recondition rods to be versus the other 6? Those two replacement Child and Albert rods will be hard to find now
