E body upper door hinge question #507181
10/25/09 07:05 PM
10/25/09 07:05 PM
Washington State
70chall440 Offline OP
Washington State
On my 73 Cuda the upper hinge has square holes and what looks like plastic bushings? Anyone know where you can get the bushings? The hole is so big that I would think you would have to have them or the door would sag.
01 Viper GTS ACR
10 Challenger RT PCP 6spd
70 Challenger 440 6 pac
73 Cuda 416 Road Racer
70 Hemi Roadrunner
01 Ram 4x4 / 98 Ram 3500
91 Stealth RT
05 Durango Hemi
09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
Re: E body upper door hinge question [Re: 70chall440] #507182
10/25/09 07:09 PM
10/25/09 07:09 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The hinges were sealed with seam sealer. It "squished" into the square holes. You are not the first one to assume it was a bushing or plug.
Re: E body upper door hinge question [Re: Alaskan_TA] #507183
10/25/09 07:29 PM
10/25/09 07:29 PM
Washington State
Washington State
Really? It sure looks like a bushing. I am having an issue getting the gap established in the door so I removed it to see what was going on and found this material.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: E body upper door hinge question [Re: 70chall440] #507184
10/25/09 08:56 PM
10/25/09 08:56 PM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
I just had to take a set of F body hinges that were wore slap out and weld up the holes and redrill them. They work like new now. I couldnt find a repair kit for them. I found everything else but no F body. My passenger door, You had to pick it up to shut it before.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: E body upper door hinge question [Re: StandOnIt] #507185
10/25/09 10:21 PM
10/25/09 10:21 PM
Washington State
Washington State
that sucks.. My problem is that the door doesnt seem to want to move far enough forward to provide the right gap at the rear. Part of it might be the seam sealer/bushing.. I stripped out the top bolt going into the A piller so now I either have to try and put a heli coil in there or weld it up, redrill it and tap it. I have access so it is possible. The hole that stripped out in a peice of 1/4 steel which seems to be spot welded but it is solid and I am not sure how much I want to beat on it to get it out.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: E body upper door hinge question [Re: 70chall440] #507186
10/25/09 11:25 PM
10/25/09 11:25 PM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
Can ya tap it out and put a little bigger bolt? You can drill it out and put a threaded insert in it. I never have liked helicoils. Havent ever had alot of luck with wire wound up, but, one bolt doesnt have tons of pressure on it. The other two will take the load.
Re: E body upper door hinge question [Re: StandOnIt] #507187
10/25/09 11:44 PM
10/25/09 11:44 PM
Washington State
Washington State
Not much room for a larger bolt. I have used a lot f heli coils and if they are put in right they seem to work although they work better if they are in something deep. I will have to look at it. I could weld a nut on the back side as well.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
