E body upper door hinge question
#507181
10/25/09 07:05 PM
10/25/09 07:05 PM
Posts: 181 Washington State
70chall440
Washington State
On my 73 Cuda the upper hinge has square holes and what looks like plastic bushings? Anyone know where you can get the bushings? The hole is so big that I would think you would have to have them or the door would sag.
01 Viper GTS ACR 10 Challenger RT PCP 6spd 70 Challenger 440 6 pac 73 Cuda 416 Road Racer 70 Hemi Roadrunner 01 Ram 4x4 / 98 Ram 3500 91 Stealth RT 05 Durango Hemi 09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
Re: E body upper door hinge question
[Re: Alaskan_TA]
#507183
10/25/09 07:29 PM
10/25/09 07:29 PM
70chall440
Washington State
Really? It sure looks like a bushing. I am having an issue getting the gap established in the door so I removed it to see what was going on and found this material.
[Re: 70chall440]
#507184
10/25/09 08:56 PM
10/25/09 08:56 PM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
I just had to take a set of F body hinges that were wore slap out and weld up the holes and redrill them. They work like new now. I couldnt find a repair kit for them. I found everything else but no F body. My passenger door, You had to pick it up to shut it before.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
[Re: StandOnIt]
#507185
10/25/09 10:21 PM
10/25/09 10:21 PM
70chall440
Washington State
that sucks.. My problem is that the door doesnt seem to want to move far enough forward to provide the right gap at the rear. Part of it might be the seam sealer/bushing.. I stripped out the top bolt going into the A piller so now I either have to try and put a heli coil in there or weld it up, redrill it and tap it. I have access so it is possible. The hole that stripped out in a peice of 1/4 steel which seems to be spot welded but it is solid and I am not sure how much I want to beat on it to get it out.
[Re: 70chall440]
#507186
10/25/09 11:25 PM
10/25/09 11:25 PM
StandOnIt
Baton Rouge, La.
Can ya tap it out and put a little bigger bolt? You can drill it out and put a threaded insert in it. I never have liked helicoils. Havent ever had alot of luck with wire wound up, but, one bolt doesnt have tons of pressure on it. The other two will take the load.
