Doug Herbert SB roller cams&lifters #506744
10/25/09 09:30 AM
10/25/09 09:30 AM
ont,canada
mopartuner Offline OP
ont,canada
Has anyone on here used them?Opinions?
410 pump gas solis flat tappet cam 10.95 so far
Re: Doug Herbert SB roller cams&lifters [Re: mopartuner] #506745
10/25/09 01:45 PM
10/25/09 01:45 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
I have used the lifters, so far so good, and they drop in with the heads on.
Re: Doug Herbert SB roller cams&lifters [Re: LSP] #506746
10/29/09 11:57 AM
10/29/09 11:57 AM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
bump
Re: Doug Herbert SB roller cams&lifters [Re: mopartuner] #506747
10/29/09 02:03 PM
10/29/09 02:03 PM
South Carolina
a408swinger Offline
mopar addict
a408swinger  Offline
mopar addict
South Carolina
Im using their lifters also, no problems here either after 2 seasons and they drop right in as stated above.
Re: Doug Herbert SB roller cams&lifters [Re: a408swinger] #506748
10/29/09 05:06 PM
10/29/09 05:06 PM
ont,canada
ont,canada
Thanks for the comments,
Re: Doug Herbert SB roller cams&lifters [Re: a408swinger] #506749
10/29/09 08:08 PM
10/29/09 08:08 PM
NC
barracuda man Offline
NC
Is this a solid or hydraulic roller lifter.I take it that there is no block grinding.What about oil mods to the stock block 340.
Re: Doug Herbert SB roller cams&lifters [Re: barracuda man] #506750
10/29/09 09:20 PM
10/29/09 09:20 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
I'm talking about the solid rollers, no grinding on OE 340 block, OE lifter bores.
Re: Doug Herbert SB roller cams&lifters [Re: LSP] #506751
10/29/09 09:26 PM
10/29/09 09:26 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
do you have to run a herbert cam with them.?
ie..smaller base circle?
or any brand roller cam?
also...
what cam did you go with ..and did it make power?
heck while iam at it
what heads did you use and what valve springs are you running?
cheaspt
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Doug Herbert SB roller cams&lifters [Re: cheapstreetdustr] #506752
10/29/09 09:41 PM
10/29/09 09:41 PM
NC
NC
also...
cheaspt
Ya im thinking of going roller.Is the herbert roller cam any good.
Re: Doug Herbert SB roller cams&lifters [Re: barracuda man] #506753
10/29/09 09:53 PM
10/29/09 09:53 PM
ont,canada
ont,canada
I am thinking of going with the solid roller also.The smallest one on the list he has online is a 585/604 246/253@.050 has anyone heard anything about these?
Re: Doug Herbert SB roller cams&lifters [Re: mopartuner] #506754
10/29/09 10:14 PM
10/29/09 10:14 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
For what it's worth, I've used his roller lifters for years, and for my money they are as good as anything out there.
His stuff tends to be pretty decent (remember, Chet Herbert is one of the oldest, most successful cam grinders ever), so I wouldn't be afraid to use it.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: Doug Herbert SB roller cams&lifters [Re: cheapstreetdustr] #506755
10/29/09 10:27 PM
10/29/09 10:27 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
also...
cheaspt
I used the Comp .394" CR lobes, sorry, didn't measure the base circle, just made sure the oil band in the lifter was not exposed, mild ported "J" heads, Herbert 1.500" IIRC double springs, factory 340 intake ported/plenum divider removed, JE flat tops.
Ran 10.71 @ 125 in a 3200 lb. Duster @ 3800 ft.DA last week at Fontana, Ca.
Re: Doug Herbert SB roller cams&lifters [Re: LSP] #506756
10/29/09 10:34 PM
10/29/09 10:34 PM
NC
NC
Let me ask this.What roller cam would you use with a 3.31 stroke 340 +30
Re: Doug Herbert SB roller cams&lifters [Re: barracuda man] #506757
10/29/09 11:27 PM
10/29/09 11:27 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
I've used the Herbret .604/.603 cam in a small block 340. Ran 6.80-6.90s in the 1/8. Best of 6.73. Sold it to my Uncle and in his car it runs 6.70's with a best of 6.66. This was with ported 587's.
Re: Doug Herbert SB roller cams&lifters [Re: Hunted Duck] #506758
10/30/09 12:05 AM
10/30/09 12:05 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
got my cam today and lifters from dougs cam grinder nice roller lifters,cam. best prices too
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Doug Herbert SB roller cams&lifters [Re: Ian] #506759
10/30/09 08:54 AM
10/30/09 08:54 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
R5-P7 I tried sending you a PM but it was full.
I wanted to ask what the combination was and where you shift. That motor sounds real strong for a stock intake manifold.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Doug Herbert SB roller cams&lifters [Re: Rapid340] #506760
10/30/09 11:54 AM
10/30/09 11:54 AM
ok..i got lots of questions for you guys who've used them
ive got a set of dougs rollers setting behind me on my shelf..had them for over a yr.
my question is..
can you give me some indepth data..on what springs you used. would you do anything different?
what was the installed heights how did you go about getting it? lots of work or fairly simple?
ive got ported j heads..with stock length valves
and 2.02 diam..
what did you use for keepers and locks?
how did you set up your heads for these cams?
i am looking for specifics as i want to put these in my motor..
as asked previously...what type of power band did you have/shift points..power graph if you had one..?
if i could figure this out..ill be installing it into my car,, pronto..
so i am all ears...cheapst
[image][/image]
Re: Doug Herbert SB roller cams&lifters [Re: cheapstreetdustr] #506761
10/30/09 12:21 PM
10/30/09 12:21 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
Cheapstreet, I will answer a few of your questions. I am currently running a set of herberts in my 408. I had to grind my block to get the link bar passed the lifter valley. For stock heads I would run the comp 917 springs and install them at 1.750. Can't tell you what valve but they were from hughes engines. This should give you around 240 lbs of seat pressure. I ran the herbert .604/.603 roller in my 340 and it would go to 7400 but I shifted it at 6800. It did run about a tenth quicker if I shifted it at 7400. This was in my 340 with ported 587's from hughes.
Re: Doug Herbert SB roller cams&lifters [Re: Hunted Duck] #506762
10/30/09 12:26 PM
10/30/09 12:26 PM
my isssues are gonna be spring heights and keepers..dont know what kinda installed height i can get with whats in there now..
let me ask you about the performance...
ive looked at that cam. what stall converter did you use? how did it pull at 4500?
did it fall off any..(sound like it didnt since you mention'd shifting higher)
do you know how much cyl psi you had after installing the cam?
thanks cheapst
[image][/image]
Re: Doug Herbert SB roller cams&lifters [Re: cheapstreetdustr] #506763
10/30/09 12:36 PM
10/30/09 12:36 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
thanks cheapst
I never did check the cyl pressure. I was using JE flat top 340 pistons at .010 in the hole with a 65cc head. My convertor flashed at 5400. It was an 8" tubro action for a 904. It ran 10.89 at almost 123 was it's best in a 3200 Dart. And that was shifting at 6800. When I shifted at 7400 it was in the 1/8 mile. And I only did it a few times. Forgot to turn on my airshifter. If you could I would collapse down one of your springs and if you know anybody that has a spring height checker you can check your installed height right on the motor. This is how I did mine.
