Winter Storage #505621
10/24/09 09:17 PM
10/24/09 09:17 PM
Minnesota
Barnstorm Offline OP
Minnesota
What do you do to prep your car for at least 6mo up north storage? Pole barns, trailers non heated?
The little old lady from Pasadena is back!
Re: Winter Storage [Re: Barnstorm] #505622
10/24/09 10:04 PM
10/24/09 10:04 PM
Lehigh Acres, Florida
rickstershemi Offline
Winter Storage....what's that
Rickster
Re: Winter Storage [Re: Barnstorm] #505623
10/24/09 10:23 PM
10/24/09 10:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think I'm going to put it in the shop so it'll
get to stay in the trailer on stands, anti freeze,
loosen the valves... maybe some stabil for the carb
Re: Winter Storage [Re: Barnstorm] #505624
10/24/09 10:36 PM
10/24/09 10:36 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i normally run the engine till it's nice and hot then change the oil/filter. refire the engine, dump some marvel mystery oil down the carb while feathering the throttle to get everything nice and oiled. shut it down, back off the rockers, drain the cooling system and carb, cover the carb/headers, put battery maintainer on the battery. you can put it on stands but remember it may squash rebound bumpers if you use them. don't forget varmints can be a problem.
Re: Winter Storage [Re: MR_P_BODY] #505625
10/24/09 10:37 PM
10/24/09 10:37 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
MR P i wondered about the stands and if you put a plate under it to help support it on the floor of the trailer.
i also just drain water,take out the valvetrain.i have an air to water intercooler i have to remove though so the whole blower deals comes inside on the endtable setup just like on the engine.
Re: Winter Storage [Re: blownzoom440] #505626
10/24/09 10:42 PM
10/24/09 10:42 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Pump up the slicks to 20 lbs.. winch it into the trailer and head south. Kinda cold on the coast today, only 74
Re: Winter Storage [Re: blownzoom440] #505627
10/24/09 10:51 PM
10/24/09 10:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have some 3/4 plywood pieces for my stands to sit,
no problems... I have diamond plate floor over the
wood floor so I just dont want it all scratched up
Re: Winter Storage [Re: jamesc] #505628
10/25/09 10:47 AM
10/25/09 10:47 AM
Minnesota
Minnesota
Thats all good. Helps alot to continuosly run a small fan in my non vented trailer [but not air tight] for condensation issues. I also fog the motor with Marvel or Deep Creep.
