Hemi Charger starter shield #505563
10/24/09 08:03 PM
10/24/09 08:03 PM
AZ
FYone Offline OP
FYone  Offline OP
AZ
Lots of conflicting info on this ,was a starter shield ONLY used on Hemi cars with automatics or standards as well ?
Re: Hemi Charger starter shield [Re: FYone] #505564
10/24/09 08:22 PM
10/24/09 08:22 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
your talking the sheet metal plate with gasket bolted to drivers rail, its on most all b-body mopars from factory. sean some hemi cars have it and some not dont think it was anything to do with trans option
MOPAR OR NO CAR
Re: Hemi Charger starter shield [Re: hemigod426] #505565
10/24/09 09:03 PM
10/24/09 09:03 PM
AZ
FYone Offline OP
FYone  Offline OP
AZ
Well that's what I thought .... Galen said only Hemi Auto's .....
Re: Hemi Charger starter shield [Re: FYone] #505566
10/24/09 10:26 PM
10/24/09 10:26 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
What year? Are you talking about the metal shield on the starter, shield on frame or metal gasket between the starter and the bellhousing?
Re: Hemi Charger starter shield [Re: Snoopy] #505567
10/25/09 12:01 AM
10/25/09 12:01 AM
AZ
FYone Offline OP
FYone  Offline OP
AZ
The metal , notched shield ( rubber gasket ) , on the frame , 1969
Re: Hemi Charger starter shield [Re: FYone] #505568
10/25/09 07:48 AM
10/25/09 07:48 AM
Snoopy Offline
Snoopy  Offline
According to the engineering print, P/N 2925315 - Front Side Rail Lower Splash Shield was for B-Body Automatic transmission only. No mention of engine type.
68-70 B-Body & 70 340 E-Body.
Re: Hemi Charger starter shield [Re: Snoopy] #505569
10/25/09 12:12 PM
10/25/09 12:12 PM
AZ
FYone Offline OP
FYone  Offline OP
AZ
Thank you for your help !
