How fast with a ladder bar car #505480
10/24/09 06:26 PM
10/24/09 06:26 PM
Illinois
Ted P Offline OP
Ted P  Offline OP
Illinois
I'm currently running a 2600lbs duster with me in it. It runs 8.60's with 1.24 60ft. Looking to upgrade the power and was wondering how much can a ladder bar car take before needing to switch to four link? Looking to go in the 7's
Post deleted by Defbob [Re: Ted P] #505481
10/24/09 07:44 PM
10/24/09 07:44 PM
Re: How fast with a ladder bar car #505482
10/24/09 07:57 PM
10/24/09 07:57 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Friend Sam use to run high 7's in his 3500lb Heavy Street Chevelle. It was a Kenny Webber built chassis. He switched to a ProCar 4-link chassis a few years ago.
so I'd say atleast 7's. never seen anyone go 6's, but why not? just put the biggest heim joint you can find on the front, like a Johnny Joint
Re: How fast with a ladder bar car [Re: Defbob] #505483
10/24/09 08:36 PM
10/24/09 08:36 PM
Illinois
Ted P Offline OP
Ted P  Offline OP
Illinois
Thanks for the I think I'll build the power and then see if I have a problem. What the heck is a Johnny Joint?
Re: How fast with a ladder bar car [Re: Ted P] #505484
10/24/09 09:46 PM
10/24/09 09:46 PM
NC
440Jim Offline
440Jim  Offline
NC
Anything can be done, but that is the hard way. If that is a stock frame car with backhalf and normally aspirated (no power adder), I think you are on the edge at that weight and ET. Are you running a 2 speed transmission, that makes it easier?
Re: How fast with a ladder bar car [Re: Ted P] #505485
10/24/09 10:09 PM
10/24/09 10:09 PM
an8sec70cuda Offline
There's a few grudge cars around here gettin' down the track QUICK w/ ladder bars. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How fast with a ladder bar car [Re: Ted P] #505486
10/24/09 10:51 PM
10/24/09 10:51 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
its for extreme rock crawling Johnny Joint
Re: How fast with a ladder bar car [Re: Defbob] #505487
10/24/09 11:04 PM
10/24/09 11:04 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
you will be fine. Just make sure you change the front ends out every year.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: How fast with a ladder bar car [Re: 440Jim] #505488
10/25/09 08:40 AM
10/25/09 08:40 AM
Illinois
Ted P Offline OP
Ted P  Offline OP
Illinois
It's a CRT 727 2 X 3 framerails and coilovers with A arms in front. Probably could switch to a glide to calm the launch down.
Re: How fast with a ladder bar car [Re: Ted P] #505489
10/25/09 09:13 AM
10/25/09 09:13 AM
NC
440Jim Offline
440Jim  Offline
NC
Hi Ted,
After getting your PM, now I know it is you. You are definitely making some power now. Good luck in your efforts.
Re: How fast with a ladder bar car [Re: 440Jim] #505490
10/25/09 11:30 AM
10/25/09 11:30 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mike Murillo was running 7's on ladderbars 9 years ago. Plenty of cars out there doing it. Is it the best way, probably not but can you do it absolutely.
Re: How fast with a ladder bar car [Re: Al_Alguire] #505491
10/25/09 12:16 PM
10/25/09 12:16 PM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
my car is 3500lbs, with ladder bars been 1.26 sixty and 8.17 @170
Re: How fast with a ladder bar car [Re: rtstreet] #505492
10/25/09 06:58 PM
10/25/09 06:58 PM
Chicago land, IL
dafixr Offline
dafixr  Offline
Chicago land, IL
We are running ladder bars on a 70 Duster 2825#
also running in the 7's. Were do you run at? We go to GLD & Byron. May be able to help. 7.84/172 1.15 60ft
Re: How fast with a ladder bar car [Re: dafixr] #505493
10/25/09 08:50 PM
10/25/09 08:50 PM
Illinois
Ted P Offline OP
Ted P  Offline OP
Illinois
I mostly run at RT66 but I've been to byron several times this season and made it to GLD for the mopar event and a TT.
Re: How fast with a ladder bar car [Re: Ted P] #505494
10/26/09 04:28 PM
10/26/09 04:28 PM
Chicago land, IL
dafixr Offline
dafixr  Offline
Chicago land, IL
i was there as well i have the lime green duster with the huge ass hood that is wrapped im sure you saw me there but anyway if you see out there come by and say hello we can give you a hand.
we race the imsm racing series you should come race with us we pretty much have a class for everyone there are only 3 rules the series has
door cars only
no opticle eyes or throttle stops(machanicle ones)
no dragsters
