Headgasket Repair in a Bottle #505305
10/24/09 02:01 PM
10/24/09 02:01 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
My sister in laws mechanic says her 01 Mazda 6 has a headgasket problem. He's 95% sure but he won't fix it, doesn't do that kind of work, told her $1500 job.
I think he is worried he won't get paid.
So, of course I am the car guy of the family and she asked me to fix it.
Not only do I not want to do it, but I couldn't even do it if I wanted to until 2 weeks or more.
The car is still driveable but loses coolant.
Any mechanics in a bottle worth trying? I have heard something called Blue Devil??
Hopefully something like that will fix the issue until the car dies from something else.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Headgasket Repair in a Bottle [Re: CJK440] #505306
10/24/09 02:08 PM
10/24/09 02:08 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Where is the coolant leaking into?
If it's leaking into the combustion chambers, that's going to be tough to fix in a can. KW Ceramic Seal would be the best chance. IIRC, you have to run it, then completly drain/air flush the cooling system of all/most of it's liquid. Then let it sit overnight.
If it's just seeping out of the side of the block or into the oil you could run something like Justice Brothers Radiator Stop Leak. Just used some of that on Troy's T/A on a seeping SB timing chain cover, has worked for over a year now.
Re: Headgasket Repair in a Bottle [Re: CJK440] #505307
10/24/09 02:10 PM
10/24/09 02:10 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Go to any autopart store and get the package with 6 quarter sized light brown slugs, its crushed walnuts with some other stuff mixed in its only about $3 for the package, this is what GM used in their late 90's engines from the factory. it works good. but if its a big leak nothing will work.
Re: Headgasket Repair in a Bottle [Re: ademon] #505308
10/24/09 03:45 PM
10/24/09 03:45 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I haven't even looked at it, just going by her mechanics word.
He gave her Bars leaks and it hasn't done much.
This is the stuff I was wondering about.
https://gouniversalproducts.com/product-101-Blue-Devil-Head-Gasket-Sealant.html
Re: Headgasket Repair in a Bottle [Re: CJK440] #505309
10/24/09 04:15 PM
10/24/09 04:15 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
See PM.
RIP Monte Smith
Re: Headgasket Repair in a Bottle [Re: CompWedgeEngines] #505310
10/24/09 07:27 PM
10/24/09 07:27 PM
florida
74fldart Offline
74fldart  Offline
florida
i asked the parts store counter man about blue devil a while back and he said it really works, and works so well, it was off the market for a few years because it was taking money away from repair shops. the only drawback is that you must follow the directions to a tee and you must open up the system after youve added it and let it dry completely for around 2 days it think it is. its not cheap at $60.00 a bottle but thats alot cheaper than a gasket job these days.
Re: Headgasket Repair in a Bottle [Re: 74fldart] #505311
10/24/09 07:36 PM
10/24/09 07:36 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
a quote from a sign years ago
why is there time to do the job the second time but never enough time to do it right the first time???
do the job right, leave the miracle cures to the Science...
I am truckless..
Re: Headgasket Repair in a Bottle [Re: CJK440] #505312
10/24/09 07:40 PM
10/24/09 07:40 PM
I would advise her to keep the coolant topped off (it's getting cold so keep an eye on the antifreeze protection level) and to start saving/planning for another vehicle. EDIT there is a good reason why people refuse (politely of course) to do business w family/relatives
Re: Headgasket Repair in a Bottle [Re: RapidRobert] #505313
10/24/09 08:46 PM
10/24/09 08:46 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
But have also had good luck with Mendtite (SP)
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Headgasket Repair in a Bottle [Re: MoparforLife] #505314
10/25/09 08:14 AM
10/25/09 08:14 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We used I believe Barrs leak that comes in the silver bottle.Had a few customers with GMs infamous 3.1s that had intake and a few that had a head gasket leak.They didnt want to spend 1K or more to fix them.One guy drove to Pitt from here and wanted a month out of his van.He was still driving it like 4 months later.It costs like 30 bucks for the bottle and you just add it no flushing.It wont fix something major but has worked on the smaller leaks we had.Not a permanent cure but might get her thru for a while.Rocky
Chrysler Firepower
Re: Headgasket Repair in a Bottle [Re: 340SHORTY] #505315
10/25/09 10:23 AM
10/25/09 10:23 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I know but I don't want to do the job at all.
If it was a 4 cylinder I'd be more enthusiastic but the transverse V6 is not fun. And of couse the car wasn't maintained and is nasty under the hood. I wouldn't be suprised if the tranny goes 1 month later.
What really scares me is how her mechanic is not positive its the gaskets nor will he do the job. Does he know something?? All I need to do is have the problem not as cut and dry as a gasket swap and be married to it if there is still a problem.......
Re: Headgasket Repair in a Bottle [Re: CJK440] #505316
10/25/09 10:34 AM
10/25/09 10:34 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Chris... Make every excuse to not touch it. Family will get over saying no much faster then when she has to pay and pay as the dominos start to fall and it's all your fault and you "give her adeal" and it's all your problem. JUST SAY NO
Re: Headgasket Repair in a Bottle [Re: moper] #505317
10/25/09 10:48 AM
10/25/09 10:48 AM
Couldn't have said it better myself
Re: Headgasket Repair in a Bottle [Re: RapidRobert] #505318
10/25/09 11:03 AM
10/25/09 11:03 AM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
i agree, my dad told me when i was younger, there are 5 things that you cannot mix,
Family, Friends, Money, Booze, Women!
if you put any of these 5things together, you are going to be in trouble,
Re: Headgasket Repair in a Bottle [Re: cornet684me] #505319
10/25/09 11:58 AM
10/25/09 11:58 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
wow... That makes for some boring evenings
(jk )
Re: Headgasket Repair in a Bottle [Re: cornet684me] #505320
10/25/09 12:05 PM
10/25/09 12:05 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i agree for the most part, although i've never had a problem mixing booze and friends
Re: Headgasket Repair in a Bottle [Re: moper] #505321
10/25/09 12:07 PM
10/25/09 12:07 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
dang moper ya beat me to it
Re: Headgasket Repair in a Bottle [Re: 340SHORTY] #505322
10/25/09 01:46 PM
10/25/09 01:46 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I agree, somehow I don't think a bottle of miracle-repair would have worked on this:
... and notice the pitting on the head about 1 o'clock because I drove it for months and kept adding coolant! Now I need some TIG and resurface work.
I agree with the other posters...
1) don't do the job yourself
2) have her pay someone to do it right
-Charles
Re: Headgasket Repair in a Bottle [Re: CJK440] #505323
10/25/09 03:09 PM
10/25/09 03:09 PM
Indiana, United Staes, Vevay
LikarockCrusher Offline
Well, I can say I don't believe in all that stuff about a bottle fixing a head gasket. I have had several guys try to show me it works but have always failed. And buy chance it does. How does it know not to plug up a radiator or heater core? And if those are flowing good before you put the crap in the radiator then it seems your going be out more money then if you fixed it right the first time.
