Benefit of Chevy........ #504243
10/22/09 10:16 PM
10/22/09 10:16 PM
Fitchbug, Mass.
WannaRunner Offline OP
Fitchbug, Mass.
what is the reason some guys use the chevy profile on their crank journels?? more rod availability?
~thanks
Re: Benefit of Chevy........ [Re: WannaRunner] #504244
10/22/09 10:49 PM
10/22/09 10:49 PM
Clinton Twp. Michigan
coronet1966d Offline
the same reason anyone buys a chevy or builds a chevy
parts availability and price!
Re: Benefit of Chevy........ [Re: WannaRunner] #504245
10/22/09 10:53 PM
10/22/09 10:53 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
The reason a Chevy size rod journal is used on big block strokers is that it frees up a little room. And rods and bearings may be a little cheaper.
Re: Benefit of Chevy........ [Re: forphorty] #504246
10/22/09 11:06 PM
10/22/09 11:06 PM
The chebby rod journal dia is much smaller than the b/rb so the Mopar journal can be offset ground for more stroke IE from 3.375" to 3.900" using a chebby rod bearing on the big end of a rod w chebby dimentions. EDIT I meant 3.750" for the (RB) stroke
Re: Benefit of Chevy........ [Re: RapidRobert] #504247
10/22/09 11:22 PM
10/22/09 11:22 PM
Fitchbug, Mass.
Fitchbug, Mass.
Thanks! and sorry for the newb question.....
Re: Benefit of Chevy........ [Re: WannaRunner] #504248
10/23/09 12:46 AM
10/23/09 12:46 AM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
Also, smaller parts are lighter parts. A good thing when dealing with parts that change directions VERY rapidly.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: Benefit of Chevy........ [Re: phantomx] #504249
10/23/09 12:08 PM
10/23/09 12:08 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Chevy pins are also smaller & lighter
Re: Benefit of Chevy........ [Re: topside] #504250
10/23/09 05:07 PM
10/23/09 05:07 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
yup, stroker guys use them for clearance, and the performance of them is that they are lighter.
that's why 440source offers a 440 length rod built with chevy ends--smaller journals for more crank throw clearance, and smaller pins for lighter rotating mass.
**Photobucket sucks**
