Best source for wiring harnesses? #504169
10/22/09 08:27 PM
10/22/09 08:27 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
I'm working on a 1973 Cuda for a friend of mine and there are more splices, cracked wiring and electrical tape in the engine compartment than I'm comfortable sending down the road on a car that I've worked on.
I'm chasing an electrical problem if you can believe that!
What is the best sources for electrical harness? I'm looking for function over factory/concourse correct. I see Year One has the engine harness for about $160.
Any better prices or better quality out there?
I'm probably going to have him replace all of the forward harnesses.
Re: Best source for wiring harnesses? [Re: 70Sbird] #504170
10/22/09 09:46 PM
10/22/09 09:46 PM
IN
ahy Offline
ahy  Offline
IN
If you want stock style wiring Year One is the only distributor as far as I know. There are several generic replacement harnesses - Painless offers one - but you probably would need the whole deal since connectors will be different. There was a Year One discount code in the hot deals section - worth a check if its still there and if it applies.
Re: Best source for wiring harnesses? [Re: 70Sbird] #504171
10/22/09 09:53 PM
10/22/09 09:53 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Year One has a deal with the only producer of quality harnesses. Search the board, there are lots of threads about this.
I lucked out on my 73 with only good cleaning and re-wrapping needed for the engine and lighting harnesses under the hood.
The dash harness had some petrified vinyl in it from overheating but you can score non-Rally harnesses pretty cheap on ebay since a lot of dashes have been converted to Rally. Just swiped the wires out of the used harness and re-wrapped them into my survivor harness.
Craig
Re: Best source for wiring harnesses? [Re: denfireguy] #504172
10/22/09 10:14 PM
10/22/09 10:14 PM
Cleveland,Ohio
CtownChris Offline
CtownChris  Offline
Cleveland,Ohio
Evans Wiring Harnesses.
evanswiring.tripod.com
see pg 99 in MCG Dec 09
$105 for engine harness
"Always go forward: Never go straight"
