Re: Where to find rear main seal?
[Re: Mopar-Al]
#503915
10/22/09 05:40 PM
10/22/09 05:40 PM
RapidRobert
Carquest & it might be listed for a SB. EDIT On second thought I cant remember if I got mine for a SB to use on a BB or vice versa but as said they do have em & comes with this aluminum silicone rtv
[Re: CYACOP]
#503916
10/22/09 11:35 PM
10/22/09 11:35 PM
Posts: 4,150 lewiston, ID
cornucopia
lewiston, ID
I bought a fel-pro rope for my 440 2 years ago from my local NAPA and it took a week to get it. they told me that I ordered and bought the LAST rope seal that Fel-Pro had...the actual last one. anywhere. forever. were they crazy?? maybe...I still have it. never used it.
[Re: poison_ivy]
#503919
10/23/09 07:41 AM
10/23/09 07:41 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
Timely thread. My 1500 mile Speedomotive built big block is puking oil out the rear main. Pulling the engine today. Sounds like I'll be buying a mop. Any other suggestions regarding sealing ths thing up. Positive that it is the rear main as the bellhousing area of the trans was soaked with engine oil.
This is the land of the free
because of the brave
[Re: Snoopy]
#503925
10/23/09 10:13 PM
10/23/09 10:13 PM
Posts: 3,958 SW Fla.
CYACOP
SW Fla.
Will the Poly rear seal work?
Yea that might work if the thickness is correct. Have you used it before?
[Re: CYACOP]
#503926
10/24/09 12:06 PM
10/24/09 12:06 PM
Posts: 108 Sweden
6pakdude
Sweden
Poision Ivy and the rest with a leaking BB rear main seal I have the same problem with my rebuild 440. How do you install/cut the graphtite rope seal, flat with the surface in block and alu housing.Do you oil it before installation. Is it possible to push it in place with the crank installed? Or do you pack it real hard? And finally what do you use between the block and rear seal housing. Please explain. peter
[Re: 6pakdude]
#503927
10/24/09 01:22 PM
10/24/09 01:22 PM
RapidRobert
Carquest just ordered me one (a rope seal)for a 440 a victor reinz # JV551
