Spool? #503505
10/22/09 08:12 AM
10/22/09 08:12 AM
Anonymous OP
Anonymous OP
Can you run a spool with stock axles,in a mid to low 11 second a body with slicks?
THANKS EDDIE B
Re: Spool? #503506
10/22/09 08:19 AM
10/22/09 08:19 AM
an8sec70cuda Offline
It's never a good idea to run a spool with stock axles. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Spool? #503507
10/22/09 08:19 AM
10/22/09 08:19 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
FWIW, I ran one W/ stock axles in a 12 sec 3400# B body W/ wide slicks and eventually found the splines on one had twisted.
Re: Spool? [Re: an8sec70cuda] #503508
10/22/09 09:28 AM
10/22/09 09:28 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
It will break.. Don't ask how I know... I was young...
Re: Spool? [Re: 70dusterjohn] #503509
10/22/09 09:34 AM
10/22/09 09:34 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
The rulebook says no.
Re: Spool? [Re: BobR] #503510
10/22/09 09:37 AM
10/22/09 09:37 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Well, I did with a 360 SB and never had any problems making about 400 hp + 150 hp nitrous. I kept breaking the suregrip unit so I switched to a spool.
Re: Spool? [Re: TheOtherDodge] #503511
10/22/09 10:04 AM
10/22/09 10:04 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
can you use stock axles in a dana 60 with a spool?
Re: Spool? [Re: mopar dave] #503512
10/22/09 12:07 PM
10/22/09 12:07 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
NHRA requires that any car that goes 10.99 or quicker or any car that has a spool to use aftermarket axles.
Re: Spool? [Re: BobR] #503513
10/22/09 06:46 PM
10/22/09 06:46 PM
ky
68roadrunner Offline
ky
i did in my dana, as long as i was footbreaking. changed when i went to trans brake. 7.10 - 7.20's in the 1/8 at 3400lbs
