Page 3 of 3 1 2 3
Re: Milodon gear drive users come on in [Re: Dustedu] #503049
07/09/11 06:17 AM
07/09/11 06:17 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I'll be replacing it with a belt drive this winter, I just don't dig the noise
As a paradox, the gear drive will then be going on my street 528 motor
Re: Milodon gear drive users come on in [Re: Tig] #503050
07/09/11 11:01 AM
07/09/11 11:01 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
What about the damper? I've run one for years on stock blocks and now an Indy Maxx. I've always run a fluidamper that I believe was stock replacement. I don't think there is a problem there. You have to set the cam thrust. I had to take a 3m "cookie" and remove material from the raised button so that the cover wasn't pushing on the cam probably was a good .060 interference. I also didnt like the news paper thing for setting lash I endded up removing one dowel pin to get rid of excess lash I had. basically clocked it on one dowel and bolt it down. With the cover off you can "feel" the lash. I do like it though,set the cams .050 intake number and line the gear bolts and adjust from there for preferance. Very fast set up.
Re: Milodon gear drive users come on in [Re: B1MAXX] #503051
07/09/11 01:50 PM
07/09/11 01:50 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
With the stock replacement ATi superdamper you will catch the cover, don't ask me how I know
Re: Milodon gear drive users come on in [Re: Tig] #503052
07/10/11 12:07 PM
07/10/11 12:07 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I builted a 572 and put a Milodon gear drive on and i like it and it makes just a little noise and it works real good and looks nice a friend run one for 15 years and now has one on a HEMI .ATI super damper 917475E it`s a 7" alum with B V8-oem front and went right on and works GOOD LUCK.
Re: Milodon gear drive users come on in [Re: steeldust] #503053
07/10/11 12:47 PM
07/10/11 12:47 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I bought this one years ago for $50 at a swapmeet. As yet I've been unable to determine who made it. It didn't look like it had ever been used. It goes on the stock pins and then you adjust gear clearance. The idler is on the right side as opposed to most others being on the left (should that matter?). It has timing marks on the gears but they're kind of useless because the idler is not the same size as the bottom gear so as soon as the motor is turned over once, the marks won't line up again for God knows how many more turns! What I need to know is how much clearance the gears need and how you get that (I've heard you run a piece of paper though each gear and that's the clearance - about .006")
Re: Milodon gear drive users come on in [Re: Stanton] #503054
07/10/11 01:23 PM
07/10/11 01:23 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
It may work if you get number one up top dead center and put a paper in the gears the marks is to let you advance or retart the timing that`s the way it should work good luck.
Re: Milodon gear drive users come on in [Re: steeldust] #503055
07/11/11 02:00 PM
07/11/11 02:00 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
917475E is the ATi part # listed for non oem covers. It's for "Donavan & KB Gear drive or Indy timing cover".
Sorry to be a pedant, just dont want people making the same mistake I did.
Re: Milodon gear drive users come on in [Re: Tig] #503056
07/11/11 08:28 PM
07/11/11 08:28 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
That`s what i put on my motor and my fuel pump pulley went right on the same way it was on my stock Damper but i had to put longer bolts in the pulley and it work with my Milodon gear drive . And i run motor plates and my water pump went right on
Re: Milodon gear drive users come on in [Re: steeldust] #503057
07/11/11 08:55 PM
07/11/11 08:55 PM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
We use a gear drive as well, I switched back from a Jessel belt. gear drive is the most accurate.
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: Milodon gear drive users come on in [Re: poppaj] #503058
07/12/11 12:30 PM
07/12/11 12:30 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Under all the other STUFF Milodon Gear Drive. By far the most accurate!
Re: Milodon gear drive users come on in [Re: poppaj] #503059
07/12/11 09:14 PM
07/12/11 09:14 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
took it all apart and set the lash and sounds more normal now! still has the whine but not as much! I just used the paper setup and tightened everything back down
Mopar Performance
Re: Milodon gear drive users come on in [Re: moparniac] #503060
07/12/11 11:22 PM
07/12/11 11:22 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
Sounds good man it`s going to make a little noise but not much good luck.
Page 3 of 3 1 2 3
