Milodon gear drive users come on in
#503009
10/21/09 06:55 PM
10/21/09 06:55 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Who uses them? Who has used them and dont like them? What are the Pro's and Con's? How hard are they to install? How long do they last? Thinking about stepping up to one of these for my hemi..
Are they noisy?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Milodon gear drive users come on in
[Re: HPMike]
#503014
10/21/09 07:21 PM
10/21/09 07:21 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
I had 3 of them.All Milodon type with the single idler. One in a Turbo Buick Stage 2 V6, 340 Mopar and 572 Hemi. All three were set with proper clearance. The Buick and the 340 were very quiet. For some reason the one on my Hemi is noisy. I think it may have something to do with the idler bolted to the aluminum cover. I actually had it in two different blocks so I know its not a clearance issue. Besides the noise, I like the precise timing that the gear drives offer. My Buick has over 3500 street miles with a solid roller and moderate spring pressures and getting ready to tear it down for inspection but don't expect to find any wear or problems with the gear drive. Based on my experience, I would recomend it to anyone. As stated in the previous post, initial set-up is a little tricky but once it is set, it will stay there.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: hemi-itis]
#503017
10/21/09 09:33 PM
10/21/09 09:33 PM
Posts: 6,295 U.S.
moparniac
U.S.
I am gonna run the milodon this time around.... what the trick to adv/ret them.....
Mopar Performance
[Re: moparniac]
#503019
10/21/09 09:49 PM
10/21/09 09:49 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I really like mine got two one in the box form my next 542 and one that came with this JWD 452. First yo put them on with no lower dowel pins and get gear clearance right drill to 5/16 and install 5'16 dowels and that is done. Trick is there are no timing marks! so you get your degree wheel on at TDC! one of these is the cats butt for this!! http://chucker54.stores.yahoo.net/crtusowidewh.html you turn the cam to .050 lift and turn the crank to the @.050 number you desire and then line the top gear up so 7 bolts line up perfectly and tighten gear then do your regular degree checks to make sure where you are!! the mark things and any advancing and retarding of cam from where you are is done buy lining numbers up to the original 1 mark!! So if you have a 260 @ .050 cam and you want it at 106 you devide 260 by 2 = 130 then you subtract 106 this leave 24 so you want @.050 lift at 24 BTDC (before)
[Re: Dodgem]
#503025
10/21/09 10:02 PM
10/21/09 10:02 PM
Posts: 20,593 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
My brother has one in a 455 olds and another going in a 350. You can't hear the gear drive on the 455 because of the 3.5" exhaust. They do take a little time to install them. On a related note has anyone ever ran a belt and and a gear drive back to back? My machinist had a single idler gear drive on an injected 355 sbc and tried a jessel belt drive for the heck of it. The belt drive slowed the cars 60' time and as soon as he put the gear drive back in it returned to normal. He came to the conclusion that the belt was stretching a little when the car was taking off and in turn it was throwing the timing off enough to kill a little power. This particular engine is in a flyweight opel gt and revs to 8-9k very easily.
[Re: Neil]
#503026
10/21/09 10:07 PM
10/21/09 10:07 PM
Bob_Coomer
Rock Springs
Keep'em coming guys.. What mods if any are required to the after market MP blocks, I actually have a World. 4.5 bore version. I tried to read the installation instruction on the web site. It would have probably understood it better If I had the parts in front of me, or any experience with these.
[Re: Bob_Coomer]
#503028
10/21/09 10:36 PM
10/21/09 10:36 PM
Posts: 43,200 Bend,OR USA
Cab_Burge
I have installed and used all three of the Milidon, Kieth Blacks and Donovan single idler gear drives for the B-RB & Hemi motors and maybe one of them on a SB Mopar(can't really remember or not on the SB. They are reliable and accurate, some of the early production blocks needed grinding inside the block to clear the idler, some didn't
