oil in vally pan #501726
10/19/09 09:25 PM
10/19/09 09:25 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
I have been getting oil laying in the vally pan after a run. can not figure out where its coming from. the pan is not cracked and has been changed 3 times. I use the felpro 1215, with the thin paper gaskets on either side of intake and RTV red on both ends and in all four corners. no oil shows on paper gaskets when removed. this is not a "film" or droplets, this is oil puddled in pan. clean it off, make a pass, check and its back. anyone seen this before? (440, cast iron heads, team G manifold, 1050 carb)
Thanks, Brian Dunnigan
Re: oil in vally pan [Re: '72CudaRacer] #501727
10/19/09 09:50 PM
10/19/09 09:50 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
do you seal the intake man. bolts with rtv?
Re: oil in vally pan [Re: bonefish] #501728
10/19/09 09:54 PM
10/19/09 09:54 PM
Mooresburg, Tn
Mooresburg, Tn
I have not sealed bolts, but bolts are always tight.
Re: oil in vally pan [Re: bonefish] #501729
10/19/09 09:55 PM
10/19/09 09:55 PM
Port Mcneill,B.C.Canada
I
Islandcuda Offline
Islandcuda  Offline
I
look real close along the valve covers, also run a small bead of silicone along the pan and intake, it might not be right but I didn,t want to take mine apart and reseal, it worked for me, still not sure where it was leaking, Tim
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: oil in vally pan [Re: Islandcuda] #501730
10/19/09 10:02 PM
10/19/09 10:02 PM
Mooresburg, Tn
Mooresburg, Tn
The crazy thing is that the exposed intake surface of the heads, the intake manifold, distrib. ect, all dry. not even droplets.
Re: oil in vally pan [Re: bonefish] #501731
10/19/09 10:03 PM
10/19/09 10:03 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Many times it's the bolts. Even though they are tight, they can seep a bit. I have also seen more than one valley pan that develop a tiny crack in the center under the manifold. Usually because the pan didn't fit too good and "stretched" when the manifold got tigtened down.
just a thought
MB
Re: oil in vally pan [Re: HPMike] #501732
10/19/09 10:09 PM
10/19/09 10:09 PM
Mooresburg, Tn
Mooresburg, Tn
Right now I'm scratching my head, not like I'm new to this BB racing thing, but I'm open to ANY & ALL susgestions. Believe me, I'm willing to try most any thing at this point.
Re: oil in vally pan [Re: '72CudaRacer] #501733
10/19/09 10:13 PM
10/19/09 10:13 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Have you looked at the rear oil pressure sender/ oil line area?
Re: oil in vally pan [Re: '72CudaRacer] #501734
10/19/09 10:15 PM
10/19/09 10:15 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Sorry, Brian, I missed the point in your original post about not seeing any cracks in the pan and changing it out. . Try sealing the bolts with RTV. Oil leaks are very frustrating..
MB
Re: oil in vally pan [Re: HPMike] #501735
10/19/09 10:23 PM
10/19/09 10:23 PM
Mooresburg, Tn
Mooresburg, Tn
Thanks for the help guys, any one else with ideas will be greatly appricated.
Brian
Re: oil in vally pan [Re: rowin4] #501736
10/19/09 10:25 PM
10/19/09 10:25 PM
Mooresburg, Tn
Mooresburg, Tn
Yes, its dry there too.
Re: oil in vally pan [Re: '72CudaRacer] #501737
10/19/09 11:19 PM
10/19/09 11:19 PM
Cincinnati
Q
Quiksilver II Offline
Q
Cincinnati
Stupid question. But have you angle grounded the heads? Also the oil presure senser will sometimes only leak (spray) on top end.
Rick.
Re: oil in vally pan [Re: '72CudaRacer] #501738
10/19/09 11:34 PM
10/19/09 11:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You said you wipe it clean before each pass.... first
how much are you talking... a few drops or a 1/4 cup.
Next, do you see any telltales of oil coming down the
side of the valley pan.... if you rev it up do you
see anything
Re: oil in vally pan [Re: bonefish] #501739
10/20/09 12:52 AM
10/20/09 12:52 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Seal the bolts with permatex thread sealer. Works great and solved the same problem for me. Someone said rtv was a bad idea because it'll fall into the heads when you pull the bolts out next time.
