How far should I go with the new heads/cam on my 512? #501166
10/19/09 02:09 PM
10/19/09 02:09 PM
Milwaukee, WI
joflaig Offline OP
joflaig  Offline OP
Milwaukee, WI
I've been running stock eddy heads and a hydraulic cam on my 512 for over a year now, puts out 540 hp and 612 fpt. This is with a 8 3/4 rear and 3.55 gears. I can run high 11s.
This morning I dropped the car off at the shop for the winter project work. Included in this, along with a lot of chassis stiffening and a Dana 60 w/4.10s, is a Gear Vendors overdrive for the 727.
Since this is a street/strip car I am wondering when it comes along to the heads, intake, cam and torque converter swap (in April or so), how agressive I should go? I'm going with Indy heads and intake, plus a Comp solid roller cam and likely a 9.5" torque converter. To keep it streetable, I''d think the compression should be at 11:1, no?
Anyway, it's nothing to add a 100 horses under this scenario, but functionally speaking why shouldn't I be more agressive with my cam choice since for regular cruising I'll have the OD? What's the downside to going to 700hp+ vs an easy 650hp? At the track the upside is FUN (little downside), but on the street I'm not so sure --sorry, no experience with 700hp street cars . Gas milage is not really a concern here. I think the OD will mitigate a lot of the negatives on street if I were to go more agressive.
Opinions? Ideas? Suggestions?
Thanks.
Re: How far should I go with the new heads/cam on my 512? [Re: joflaig] #501167
10/19/09 02:45 PM
10/19/09 02:45 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
how much maintenance do you want to do to the valve train? I just choose a little over .600 lift solid roller for my street engine because this was the biggest grind that I could run with minimal maintenance. Any bigger than this and the springs have to be so strong that parts life is a concern.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: How far should I go with the new heads/cam on my 512? [Re: HemiRick] #501168
10/19/09 02:59 PM
10/19/09 02:59 PM
Milwaukee, WI
joflaig Offline OP
joflaig  Offline OP
Milwaukee, WI
Good question. Almost none! I can put up with adjusting the valves for valve lash once a season or else I'd stick with the a hydraulic cam, but I don't want to be constantly muching with the motor at all.
Re: How far should I go with the new heads/cam on my 512? [Re: joflaig] #501169
10/19/09 04:39 PM
10/19/09 04:39 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
That's what I wanted long parts life with just an occasional adjustment. My engine is a Hemi. So I dont know if the answer would be different for a BB but I doubt it as the limiting factor is still the spring pressure vs. parts life. My cam is 245/256 @ .050 .618 .631 lift w/ Comp 999 springs. I choose a solid over a hydraulic for 2 reasons, 1st is I didn't want to take motor apart to grind on block and 2nd it's upgradable to a bigger one!
Take care,
Rick
Re: How far should I go with the new heads/cam on my 512? [Re: HemiRick] #501170
10/19/09 04:43 PM
10/19/09 04:43 PM
Milwaukee, WI
joflaig Offline OP
joflaig  Offline OP
Milwaukee, WI
Have you had it dynoed?
Re: How far should I go with the new heads/cam on my 512? [Re: joflaig] #501171
10/19/09 06:19 PM
10/19/09 06:19 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
No Comp has not made the cam yet!! with the old cam it made 600 HP.
Take care,
Rick
Re: How far should I go with the new heads/cam on my 512? [Re: joflaig] #501172
10/19/09 08:37 PM
10/19/09 08:37 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Here's what I'm running in my 511 wedge with Indy EZ heads. The car is a 69 Bee with AC, PB and PS and ran an 11.74 on 275/15 BFG drag radials.
