2 short blocks, 2 cams - which cam with which block? #500533
10/18/09 08:46 PM
10/18/09 08:46 PM
Tennessee
WyleECoyote Offline OP
Tennessee
Ya gotta love spare parts sitting around!
I have two short blocks assembled:
A 383, 12.5:1
A 440, 10.5:1
I have two Crower roller cams:
.550 lift
.650 lift
I want to get my Road Runner back on the road with one of these engines.
4-speed car, 4.89 gears, 29.5 inch M/T Sportsmans.
Commute is 25 mile to work - 17 of that is posted 65mph and the rest is redlights... ( )
MPG is not a factor.
FUN is a factor.
Which CU/Compression block with which cam would work best for this scenario "fun-driving" would you all put together!??
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: 2 short blocks, 2 cams - which cam with which block? [Re: WyleECoyote] #500534
10/18/09 09:04 PM
10/18/09 09:04 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
12.5:1 sounds a like race gas territory to me.
I'd put the smaller cam in the 440.
Re: 2 short blocks, 2 cams - which cam with which block? [Re: Neil] #500535
10/19/09 07:04 AM
10/19/09 07:04 AM
Tennessee
Tennessee
...hmm
...put all the "big guns" (compression/cam) in one application for racing and combine the smaller stuff for the street...
On the street, I will have more focus on the lower rpm range vs at the strip where I'll need some top end power for getting to the end of the track.
With the new tilt front end - swapping out the street engine for the strip engine shouldn't be a huge process...
I'm liking the idea
Other comments?
Wile E. Coyote
Re: 2 short blocks, 2 cams - which cam with which block? [Re: WyleECoyote] #500536
10/19/09 08:20 AM
10/19/09 08:20 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
The 550 roller in the 440 would be the better choice. You didnt mention head options. But the 440 will live a lot longer do to obvious components.
Re: 2 short blocks, 2 cams - which cam with which block? [Re: Mopar-Al] #500537
10/19/09 12:47 PM
10/19/09 12:47 PM
Tennessee
Tennessee
Heads will be 452's with port work. I have too many cars to afford aluminum heads!
Wile E. Coyote
