2 short blocks, 2 cams - which cam with which block?
#500533
10/18/09 08:46 PM
10/18/09 08:46 PM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
Ya gotta love spare parts sitting around! I have two short blocks assembled: A 383, 12.5:1 A 440, 10.5:1 I have two Crower roller cams: .550 lift .650 lift I want to get my Road Runner back on the road with one of these engines. 4-speed car, 4.89 gears, 29.5 inch M/T Sportsmans. Commute is 25 mile to work - 17 of that is posted 65mph and the rest is redlights... ( ) MPG is not a factor. FUN is a factor. Which CU/Compression block with which cam would work best for this scenario "fun-driving" would you all put together!??
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: 2 short blocks, 2 cams - which cam with which block?
[Re: Neil]
#500535
10/19/09 07:04 AM
10/19/09 07:04 AM
WyleECoyote
Tennessee
...hmm ...put all the "big guns" (compression/cam) in one application for racing and combine the smaller stuff for the street... On the street, I will have more focus on the lower rpm range vs at the strip where I'll need some top end power for getting to the end of the track. With the new tilt front end - swapping out the street engine for the strip engine shouldn't be a huge process... I'm liking the idea Other comments?
[Re: Mopar-Al]
#500537
10/19/09 12:47 PM
10/19/09 12:47 PM
WyleECoyote
Tennessee
Heads will be 452's with port work. I have too many cars to afford aluminum heads!
