Cooling Issue #498772
10/16/09 04:58 PM
10/16/09 04:58 PM
New Zealand
V
vs2 Offline OP
vs2  Offline OP
V
New Zealand
Hi. Pretty new here but need some help.
I'm just getting my car on the road but have a cooling issue.
Has a 4 core, triple flow rad with twin SPAL 1780cfm fans and shrouding.
Engine is a new KB588ci with Stage V heads.
Problem: Just idling (as have yet to do roadtest) the car sometimes maintains a 190F temp, then other times it climbs to 205-210+ then I shut it off. Thermostat is a 180F one. Belts are not slipping and alternator is 180amp and charging circuit is good. One strange thing I do notice is that the outlet side of the rad is a lot cooler than the inlet side which make sense but then why am I overheating. It is almost like the water flow through the block is been restricted and flowing too slowly through the cooling system. There are no air blocks.
Cheers.
Re: Cooling Issue [Re: vs2] #498773
10/16/09 05:19 PM
10/16/09 05:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
210 at idle is not high temp. When you raise the idle what does the temp do?
Re: Cooling Issue [Re: stumpy] #498774
10/16/09 06:01 PM
10/16/09 06:01 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Try some Royal Purple / Water Wetter. It drops the surface tension of your cooling system so the coolant flows better. It dropped my system 10 degrees. What size thermostat do you have? perhaps its a small throat and the water is restricted? What water pump do you have? If its the Non-AC then it has less fins and that will reduce your flow as well. With dual SPAL fans and a 4 core radiator that should not be happening.
I know its a lame question but you do have a spring installed on the lower radiator hose right?
How about jetting on the carb (or is it fuel injected) if its running lean you could be heating up from that
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Cooling Issue [Re: vs2] #498775
10/16/09 06:34 PM
10/16/09 06:34 PM
Welcome to the site. Though 215 isn't a dealbreaker I too would be concerned about a 25+ temp change with no other changes. I'd take out the stat for a day & see what you get as it might be sticking slightly at different times just enough to slow the flow a bit (if so it wont fix itself & will possibly stick shut & you have way too much into your eng to risk it). Holler back when you find something.
Re: Cooling Issue [Re: vs2] #498776
10/16/09 07:48 PM
10/16/09 07:48 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Are you sure on the air pockets? I thought I had all mine out then found more air. Good luck.
Re: Cooling Issue [Re: ireland383] #498777
10/16/09 08:45 PM
10/16/09 08:45 PM
Az
Crizila Offline
Crizila  Offline
Az
All good suggestions and things to check / try, but keep in mind - just because you have a 4 core rad doesn't necessarily mean you have enough rad to handle that motor. Heat transfer efficiency drops way off with the 3rd core and less than 20% by the 4th core. Thats why aluminum rads with 2 large cores transfer more heat than 3/4 core brass rads. Just something to keep in mind after you have gone through all the other scenerios.
Fastest 300
Re: Cooling Issue [Re: Crizila] #498778
10/16/09 09:57 PM
10/16/09 09:57 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I have seen a lot of cars that idling will have the temp rise like that (especially on a fresh engine) and never have a problem when driven, I really wouldn't panic until it is driven.. Take it for drive and see what happens. If youhave a prolem then lookand see what it is, but really those temps are nothing to get a whole bunch of concerned about. The new vehicles run at those temps all the time.
Re: Cooling Issue [Re: vs2] #498779
10/16/09 10:31 PM
10/16/09 10:31 PM
sg66mopar Offline
sg66mopar  Offline
You might want to check the actual water temp with a high quality meat thermometer. I went through a number of Autometer temp gauges this year on my race car and none read withiun 10 of the other. All were new gauges and not cheap ones. I also see 15 degrees difference between the sending unit port on the pump and the water in the top of the radiator.
Re: Cooling Issue [Re: sg66mopar] #498780
10/17/09 02:36 PM
10/17/09 02:36 PM
New Zealand
V
vs2 Offline OP
vs2  Offline OP
V
New Zealand
Thanks and really appreciate all your input. I'm running F.A.S.T. EFI and the temps read within 3F of the cars Autometer (Cobalt) so we think its pretty accurate.
We will pull the thermostat and take the car for a good motorway run as its a new engine. Car is not tuned yet as well. Also using water and no antifreeze yet as have the Cometic head gaskets.
Will post back our findings.
Re: Cooling Issue [Re: vs2] #498781
10/17/09 06:31 PM
10/17/09 06:31 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
why not wire the fans to a thermostatic switch and cut the guts out of the thermostat and use what's left as a restricter plate
Re: Cooling Issue [Re: Pool Fixer] #498782
10/18/09 07:28 AM
10/18/09 07:28 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Are you running a 440 SOURCE WATER PUMP ?
Re: Cooling Issue [Re: vs2] #498783
10/18/09 08:16 AM
10/18/09 08:16 AM
IN
ahy Offline
ahy  Offline
IN
"Also using water and no antifreeze yet as have the Cometic head gaskets."
Hope you dropped a can of coolant conditioner/corrosion inhibitor in the water. Any autoparts store will have it. Your nice new engine won't like straight water for very long.
Re: Cooling Issue [Re: ahy] #498784
10/21/09 12:51 AM
10/21/09 12:51 AM
New Zealand
V
vs2 Offline OP
vs2  Offline OP
V
New Zealand
Thanks for all the ideas to consider. Pulled out the stat and immediarwly noticed that the huge temp. differential that we had across the top of the rad. had disappeared. Installed a new 180 stat with three 3/16 holes and then took it for the 1st ever run (80m)and motorway temp was steady at 186F. In traffic with A/C on it climbed to 200F and stopped. Tomorrow will test it with proper coolant and water wetter in system. Seems ok and car still needs tune as only have base map in and running a bit rough. Will wait for proper tune before spinning up the Procharger.
Re: Cooling Issue [Re: vs2] #498785
10/21/09 10:07 AM
10/21/09 10:07 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The FAST tune can have a dramatic effect on temp. This is what I do and I see this all the time. Make sure the A/F ratios are in the correct range and that you are running enough timing (retarded timing will cause heat). Obviously you have to make sure that the crankshaft ref angle in the software is correct, etc.
Download "setting up the fast XFI system" from my web site.
Good luck.
Re: Cooling Issue [Re: vs2] #498786
10/21/09 12:58 PM
10/21/09 12:58 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
don't wast your money on water wetter or ice as once you put antifreeze in it does not help! works only in pure water!!
Re: Cooling Issue [Re: Dodgem] #498787
10/21/09 07:03 PM
10/21/09 07:03 PM
Can I use a can of water pump lube/antirust along with water wetter/ice for rust protection?
Re: Cooling Issue [Re: RapidRobert] #498788
10/22/09 02:12 AM
10/22/09 02:12 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yes, I have racers and customers that used Justice Brothers Super Radiator Cooler with Justice Brothers Cooling System Protector.
Real life test:
http://www.turbomagazine.com/features/0703_turp_cooling_system_additives/test_results.html
The Justice Brothers Cooling System Protector fights electrolysis, anti-rust, neutralizes acids, lubricates water pumps, and contains Supplemental Coolant Additives (SCA's)
Re: Cooling Issue [Re: Mopar_Rich] #498789
10/22/09 01:56 PM
10/22/09 01:56 PM
New Zealand
V
vs2 Offline OP
vs2  Offline OP
V
New Zealand
Good luck.
Thanks for that. I have printed out your document and will give to tuner next week. Will post back the results.
http://www.candmperformance.co.nz/index.htm
