Re: B Body Roof Skin Installation
[Re: elitecustombody]
#498603
01/15/10 12:54 AM
01/15/10 12:54 AM
Posts: 1,179 Canada
demon
Canada
A spot weld cutter is completely un necessary on a roof skin replacement. Unless you plan to save the removed roof skin there is no need to use a spotweld cutter anywhere on this job. What you do is remove all parts like the trim,windshield,roof rails etc and then melt out the lead in the joints(or bondo if it was a vinyl roof car). Then use a air chisel CAREFULLY to remove the skin aroun the perimeter without trying to seperate the welds yet- just get the majority removed. Now you have access to all the spotwelds. Use a cut off saw with a thicker zip disc to "erase" the spotwelds. As you get good you will get the feel of it and be able to go just far enough thru the top layer to let the welds pop free. Once you have all the old roof chunks gone just check all your mating areas for smoothness so the new one can drop right on. The roof of a car is the last panel welded on when new so it is an easy panel to do compared to most. You can use a regular drill bit to make the holes for plug welding. I have seen SO many people screw up panel replacement by misuse of spotweld drills. They have their place but this is a classic example of a job that has zero need for one.
LMAO!! This has got to be one of the most ignorant posts I've read in a while.
You're actually telling everyone that it's better to hack up ,rip and butcher off old skin than actually using proper tool that will remove the remove old skin without distorting not only pinchwelds ,but most important, the actual roof structure?
Not sure what your defenition of "spotweld cutter" is, but it's actually a tool that will remove spotwelds without any damage to underlaying metal and in right hands it will take about 3-5 seconds to cut each spotweld,maybe it's time you do some shopping for high quality cutter
Nowhere did I say "hack,butcher or rip off the roof" 25 years of restoring Mopars has given me plenty of experience doing panel replacement.My method is by far the least destructive as well as the least time consuming. Yes spot weld cutters have their place,but a roof skin does not require one at all and as stated by another poster,can actually do more harm than good. Try getting a spot weld cutter into the drip rails. The purpose of a spotweld cutter is to drill thru only the outer panel leaving the underlying panel unharmed.Now that is great when you want to save both panels,like when you are salvaging used panels from a parts car.If you are using a new roof,and there is no need to save the old roof,then using a spotweld cutter is redudant.In fact it creates more work because you now have little buttons left over when using a Blair Rotabroach which guess what-need grinding to make flush.By erasing the spotwelds with a cut off disc,you kill two birds with one stone.Release the spotwelds AND grinding flush.All in one step ! And no risk of drilling too deep with the spotweld cutter and damaging and weakening the panel below. My suggestion of using an air chisel to remove the surface of the roof is to gain access to areas like the drip rails and it allows one to stand inside the car with the roof surface removed to allow an easier position to get to the areas needing attention. An air chisel is a tool which can be very helpful or very destructive in the wrong hands.I have seen much damage done by a fool with an air chisel.That said,I have also seen much damage done by a fool with a spotweld cutter. Rule # 1 when doing work like this.Be careful,think before you cut and measure 3 times-cut once.If you don't feel capable of doing this work-don't even start. I have no control over how anyone handles a repair like this and everyone is going to have opinions and shortcuts and suggestions.These are merely mine and work well for me. I have specialized in metal work since the 1980's and know my trade.I can assure you I am not ignorant about panel replacement.I do it full time. Perhaps before you ridicule someone,you should take the time to consider the possibilities of other methods.
#498609
01/15/10 03:50 PM
01/15/10 03:50 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
Wow, I didn't think this would become a pissing match... Thanks for all the suggestion, I just don't dare tell you which way I'll do it so I won't get ostracized by the other side!
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 6PakBee]
#498611
01/15/10 08:46 PM
01/15/10 08:46 PM
Posts: 1,572 Jacksonville Florida
elitecustombody
I'm not going to get into which way is best. However, I have used a spotweld cutter on larger spotwelds (1/8" or so?) that seem to be structural welds (if that is the proper term) like you would find on a front inner fender or core support. Then there are these little spotwelds that look just like a pencil point. I put lower quarter patch panels on a '74 Dart one time and there must have been (no kidding) over a hundred of these suckers between the quarter and the trunk extension. It's like the guy with the welder had Parkinson's. I used a 3/32" drill bit to cut these out. I guess what I'm trying to say is that all spot welds aren't created equal.
that's nothing compared to old Porsches, everything on those cars is welded with two or three rows of 1/8" diameter spotwelds and they are 1/4" apart,
[Re: 67Charger]
#498612
01/15/10 09:32 PM
01/15/10 09:32 PM
Posts: 287 Greenville, N.C.
BarrsRestoration
Greenville, N.C.
Fair enough. If you decide to drill it, you might want to order some new drip rails.
