Re: Temperature Switch activation
[Re: 408strokerdart]
#498420
10/16/09 08:37 AM
10/16/09 08:37 AM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
Bust out the multimeter. Some are redundant ground, others are not.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: BBR]
#498421
10/16/09 09:15 AM
10/16/09 09:15 AM
Posts: 3,456 Out West
408strokerdart
Out West
Please help with my electrical ignorance....what does redundant ground do for the circuit?
[Re: max_maniac]
#498424
10/17/09 08:43 AM
10/17/09 08:43 AM
408strokerdart
Out West
I have a Be Cool rad and fan set up and the fans are temp controlled. they come on and go off at 160 and I needed them to stay on longer for cool down so I just ran a ground wire off of the temp switch and use the fans manually.
I did buy another temp control which is supposed to come on at 160 and go off at 140 but I have not installed it yet.
Russ
Thanks Russ, What control is that? I need something to do the same thing...in the same temperature range.
#498426
10/17/09 09:32 AM
10/17/09 09:32 AM
Posts: 6,353 Aurora, Oh.
max_maniac
Aurora, Oh.
Russ
Moroso temp control switch part # 63760. Will switch on at 165 and off at 140 and can comes with a switch so you have a choice for it to be automatic or manual.
Russ
#498427
10/17/09 11:00 AM
10/17/09 11:00 AM
Posts: 1,532 off the grid
340B5
off the grid
If it's a single wire,it grounds the circuit. Most likely a piezo-resistive sensor that turns the fan on through a relay. It could be that it is slightly more complicated and it senses the grounding, but I doubt that. In either case, tapping in w/ a switch to ground would turn the fans on.
Yeah, it's got a smallblock.
