727 converter questions #498299
10/15/09 10:24 PM
10/15/09 10:24 PM
Costa Mesa, CA
chache876 Offline OP
Costa Mesa, CA
What size converter is considered a 'stock' converter?
I have three converters.
The first of which I believe to be stock. It is 11," which from reading the posts on this board can range from 800-2000 depending on who you talk to.
The second of which that came with a transmission I bought that is supposed to be a higher stall converter, somewhere in the 2500 range. It is 11" It does look pretty identical to the first one.
I ordered an aftermarket converter which has a stall of 2200-2800 and its 12"
I thought that the smaller the diameter converter, the higher stall speed and vice versa?
Also, this new converter that I bought does not fit my flexplate (360 magnum). Its too big. Did they make a big block and small block converter or whats the deal? Can I get an aftermarket flexplate with the larger pattern?
Re: 727 converter questions [Re: chache876] #498300
10/16/09 09:14 AM
10/16/09 09:14 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
what is inside makes the stall to a certain point! But you are right they generally get smaller as TQ goes up. don't often see those 12" in any kind of stall they are what is on motor homes and trucks! LOL!
The flex plate you will need is a stock 440/400/413/383/361 one it is quite a bit larger. Back in the day I had to buy 318 ones for my 440 with higher stall speeds.
Re: 727 converter questions [Re: Dodgem] #498301
10/16/09 10:17 AM
10/16/09 10:17 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
There are around 3 or 4 flexplates setup. Not only the size is the difference like also one of the crank bolts is on a diff position ( offset ) than the other ones
Dunno if the offset bolt at crank is for 6 cilinders, SB or BB but is afact it does exist.
Diameter for stock converters I think is 11 3/4" and 10 3/4". Some Hemis got the larger ones in fact
Re: 727 converter questions [Re: NachoRT74] #498302
10/16/09 11:43 AM
10/16/09 11:43 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
OEM flex plates are of 2 sizes depending on the application.. They will only go on 1 way at boththe converter and at the crank shaft. (Later Magnum plates not offset)
Re: 727 converter questions [Re: MoparforLife] #498303
10/16/09 12:09 PM
10/16/09 12:09 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
OEM size was 11.75 (usually 440s )or 10.75 (318-383 ) and the Hemi was a high stall (10.75? ) The smaller flex plat is for the 10.75 and the big is for the 11.75. The 10.75 converter had many different stall speeds depending on the application and year. A nice cheap combo for a 440 car back in the day was to swap to a small block (10.75) converter for more stall.
Re: 727 converter questions [Re: MoparforLife] #498304
10/16/09 12:22 PM
10/16/09 12:22 PM
Arizona
69rrgrabber Offline
69rrgrabber  Offline
Arizona
Not to hijack the thread, but what how much duration can you go with a stock 11 inch converter in say a 440 or 383?? The stock cam was 268 duration but if I go to buy a new duration cam at 268 degrees the manufactuer recommends a bigger stall.
CAC
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: 727 converter questions [Re: THESHAKERPROJECT] #498305
10/16/09 12:22 PM
10/16/09 12:22 PM
scratchnfotraction Offline
a cheap combo,I run a stock high stall /6 verter on my 318 engine
my 440 truck will get the stock high stall for a 318 also
Re: 727 converter questions [Re: NachoRT74] #498306
10/16/09 03:12 PM
10/16/09 03:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nope, no Hemi ever came from the factory with the large converter.
It's worth repeating that there is no set stall speed for any converter, the stall speed of any given converter depends on the power input and the resistance to movement.
Re: 727 converter questions [Re: John_Kunkel] #498307
10/16/09 03:22 PM
10/16/09 03:22 PM
Upper Midwest
Upper Midwest
Thank you; Maybe tehy will believe you.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 727 converter questions [Re: John_Kunkel] #498308
10/16/09 04:55 PM
10/16/09 04:55 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
mmm maybe was on some 440 HP where I saw ?
Re: 727 converter questions [Re: John_Kunkel] #498309
10/16/09 05:03 PM
10/16/09 05:03 PM
Costa Mesa, CA
Costa Mesa, CA
I understand it depends on the torque output of the engine, but there is general range of a converter stall speed right?
Re: 727 converter questions [Re: chache876] #498310
10/16/09 07:11 PM
10/16/09 07:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'll take it to an extreme to illustrate the point, take a common converter like the popular factory "764", behind a /6 it might stall at 1400, behind a built 440 it might stall at 2800, behind a blown fuel Hemi it will never stall.
Re: 727 converter questions [Re: John_Kunkel] #498311
10/16/09 08:13 PM
10/16/09 08:13 PM
Costa Mesa, CA
Costa Mesa, CA
Ok so lets say I have a bone stock 360 with a stock converter. If I go out and buy a converter with an advertised 3000 stall, it wont stall any higher than what my stock converter does?
Re: 727 converter questions [Re: chache876] #498312
10/17/09 10:07 AM
10/17/09 10:07 AM
florida
74fldart Offline
74fldart  Offline
florida
no hes not saying that . it should stall around the
advertised speed . hes saying stall speed depends upon engine power output when your talking bone stock torque converters. thats why most good converter companies will custom make a converter for you after you give them your engine size, power out put, cam, car wt., etc.
