Billet Specialties Street lites #496430
10/13/09 06:39 PM
10/13/09 06:39 PM
White House,TN
stroked470 Offline OP
White House,TN
Is there anyone on here using a 5/8 wheel studs with the Street lite wheels. Will the studs go through the wheels as they are or will i need to drill them out to fit. I am going to build a Dana for my Charger and thinking about using 5/8 studs.
Re: Billet Specialties Street lites [Re: stroked470] #496431
10/13/09 07:09 PM
10/13/09 07:09 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My 5/8 studs slid through perfectly and the large aluminum lug nut spacers fit perfectly too.
Re: Billet Specialties Street lites [Re: ProSport] #496432
10/13/09 07:12 PM
10/13/09 07:12 PM
Orlando Florida
blown572dart Offline
Orlando Florida
ProSport how wide are your rear wheels?
Re: Billet Specialties Street lites [Re: stroked470] #496433
10/13/09 07:21 PM
10/13/09 07:21 PM
ohio
dbran451 Offline
dbran451  Offline
ohio
I put a a set of 15x14 on my dart and had to clearance the holes for the studs a friend used a set and they had to be clearance also both cars use the 5/8 stud and don't plan on running tubes with them as the hole for the tube is to close to the edge of the rim and will rip it also there is a back spacing clearance issue with disk brakes they are a great looking wheel but a pain in the A$$ to fit to the car
Re: Billet Specialties Street lites [Re: blown572dart] #496434
10/13/09 07:30 PM
10/13/09 07:30 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
15X10 with 29.5X10.5 tires.
It might depend on what brand Stud you use. I'm not sure what brand mine are. I also have drum brakes on the back of my car so they fit fine.
Re: Billet Specialties Street lites [Re: ProSport] #496435
10/13/09 08:24 PM
10/13/09 08:24 PM
Orlando Florida
Orlando Florida
Cool thanks
Re: Billet Specialties Street lites [Re: blown572dart] #496436
10/13/09 09:19 PM
10/13/09 09:19 PM
Regina Sask, Canada
V
Viper469 Offline
Viper469  Offline
V
Regina Sask, Canada
I have 15 X 15 with a 4.5" bs. I have 5/8" studs and Aerospace disc brakes. Had no clearance issues at all
Re: Billet Specialties Street lites [Re: Viper469] #496437
10/14/09 09:34 AM
10/14/09 09:34 AM
White House,TN
White House,TN
It may have something to do with the studs. I know Moroso 5/8 studs screw into the wheel and has a shoulder on them. I think Strange 5/8 studs are just a 5/8 bolt that is threaded all the way down and don't have the shoulder. That may be the difference.
Re: Billet Specialties Street lites [Re: stroked470] #496438
10/14/09 09:47 AM
10/14/09 09:47 AM
Nebraska
70VcodeCoronetRT Online tonguue
70VcodeCoronetRT  Online Tonguue
Nebraska
Look great!! Are these any lighter than Pro Stars?
Re: Billet Specialties Street lites [Re: 70VcodeCoronetRT] #496439
10/14/09 10:05 AM
10/14/09 10:05 AM
White House,TN
White House,TN
Yes they are lighter, a little harder to keep clean but look great.
Re: Billet Specialties Street lites [Re: stroked470] #496440
10/14/09 11:34 AM
10/14/09 11:34 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
how much do a 15 - 3.5 rim go for ?
1.39 9.85 - 137 mph
Re: Billet Specialties Street lites [Re: Ari440] #496441
10/14/09 03:32 PM
10/14/09 03:32 PM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
$229.95 at Summit but with the discount code they are $206.96 per wheel.
Re: Billet Specialties Street lites [Re: stroked470] #496442
10/14/09 05:00 PM
10/14/09 05:00 PM
Arizona
Chris'sBarracuda Offline
Arizona
If you use a M/W wheel stud kit as I have, you may need to grind down the nut, as it has a washer head on it. That's what I had to do on my Centerline Qualifiers--(basically the same wheel).
http://www.markwilliams.com/detail.aspx?ID=1745
Chris..
