Is there anyone on here using a 5/8 wheel studs with the Street lite wheels. Will the studs go through the wheels as they are or will i need to drill them out to fit. I am going to build a Dana for my Charger and thinking about using 5/8 studs.
If you use a M/W wheel stud kit as I have, you may need to grind down the nut, as it has a washer head on it. That's what I had to do on my Centerline Qualifiers--(basically the same wheel).
http://www.markwilliams.com/detail.aspx?ID=1745
Chris..
