Pro form main body...
#496356
10/13/09 05:45 PM
10/13/09 05:45 PM
Posts: 2,679 owt west
Thread Ender1
owt west
Does anyone have any feedback on them? I have a 700 Double Pump and have givin it some thought of installing a 950 main body. Is that gonna work proper, will it flow 950 or somewhere in between? Any help or experiences Or should i just buy the carb rating i need.
Re: Pro form main body...
[Re: BIGS]
#496360
10/13/09 06:56 PM
10/13/09 06:56 PM
Thread Ender1
owt west
Installing a 950 Body on a 700 baseplate will leave you with a "reverse" step that will not be good....The 950 body is 1.750 where it meets the base plate...and your baseplate is 1.720.....If your going to do the 950 body then also pick up a 1 3/4 (1.750) base plate....Then you have a good start to a carburetor if you have enough engine.....why not just go with the 750 body....that will match your 700 baseplate.....whats your engine specs?....Jesse
www.bigsperformance.com
I just was thinking of that before your post, i came to realize that 850 holleys have bigger baseplate blades. Im doing a 10.5 cr 410" stroker sb, hyd roller, 1 7/8 headers. I have not picked cam specs yet.
