push rod help and ???? #496301
10/13/09 04:08 PM
10/13/09 04:08 PM
nc
E
earthmover Offline OP
E
nc
I need to get push rods for my 340 and I have 2 that I am going by 1 is a adj that shows half to 1 tread and the other is a comp that shows 2 to 3 treads which would you use ....I have pic but dont know how to post I would email them if someone would like to post them for me....now ???? would one work better then the other from 1 and a half treads do I really need the custom rods made?????
Re: push rod help and ???? [Re: earthmover] #496302
10/13/09 04:43 PM
10/13/09 04:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The ones with 1 thread showing will be fine... if that
is with your lash set
Re: push rod help and ???? [Re: MR_P_BODY] #496303
10/13/09 05:04 PM
10/13/09 05:04 PM
nc
E
E
nc
yes thats with the lash set thanks mr.p love that shop you got there
Re: push rod help and ???? [Re: earthmover] #496304
10/13/09 05:37 PM
10/13/09 05:37 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Make sure that the cup is located as to get enough oil,too high and it may not get oiled properly.
Re: push rod help and ???? [Re: B G Racing] #496305
10/13/09 05:55 PM
10/13/09 05:55 PM
Hemiroid Offline
Hemiroid  Offline
I agree. And too low and it gets flung off of the adjuster threads before it reaches the cup. That's why most people shoot for 1 1/2-2 threads showing. Seems to be around the right amount to oil best and not break from being too far extended below the rocker.
Re: push rod help and ???? [Re: Hemiroid] #496306
10/13/09 06:22 PM
10/13/09 06:22 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
True,it depends on the style of rocker and the length of the adjuster above the ball and the oil hole location.
Re: push rod help and ???? [Re: B G Racing] #496307
10/13/09 07:06 PM
10/13/09 07:06 PM
nc
E
E
nc
it's the crane gold rocker with there adj..\\\\so would I be better off with the 2to3 showing....now I confussed
Re: push rod help and ???? [Re: earthmover] #496308
10/13/09 07:09 PM
10/13/09 07:09 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
1and 1/2 threads,2 maximum With Crane Adjusters
Re: push rod help and ???? [Re: B G Racing] #496309
10/13/09 07:34 PM
10/13/09 07:34 PM
nc
E
E
nc
who stocks a push rod thats 7 5/8 long anybody???
Re: push rod help and ???? [Re: earthmover] #496310
10/13/09 07:44 PM
10/13/09 07:44 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I ordered mine thru Comp Cam's, but any pushrod company can make them for you.
Re: push rod help and ???? [Re: dartman366] #496311
10/13/09 07:52 PM
10/13/09 07:52 PM
nc
E
E
nc
yea I called comp and talked to a guy today told him what I needed he said he had a set that was a few thous. short I said okay mail them came home a looked on the puter at the part # ford push rods ball ball not the ball cup I need so now I'm still looking with a set on the way thats no good ...callled them back was told to just send them back good comp. to deal with but could not help with the rods this time....told me to call smith bro...
Re: push rod help and ???? [Re: earthmover] #496312
10/13/09 08:11 PM
10/13/09 08:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I myself would put the ones in and try them... if
they are too short they wont get oil into the cup
but the oil should be shooting up and hitting the
end of the rocker area... the reason you dont want
alot of thread sticking out is the side load when
the valve is open.
Put them in and presurize the oiling system while
turning the engine over and see if they are getting oil....
I would waste $120 for a 1/2 thread unless they werent
getting oil....... JMO
Re: push rod help and ???? [Re: MR_P_BODY] #496313
10/13/09 08:18 PM
10/13/09 08:18 PM
nc
E
E
nc
thats what I was trying to fig. out cause I called smith bro. as well 160.00 plus shipping so about 170./180.00 thanks for all your replies and help guys I let you know how things work out....
Re: push rod help and ???? [Re: MR_P_BODY] #496314
10/13/09 08:22 PM
10/13/09 08:22 PM
Hemiroid Offline
Hemiroid  Offline
the valve is open.
As long as edge of the cup isn't hitting the bottom of the rocker and it's seeing some oil it should be ok.
Re: push rod help and ???? [Re: Hemiroid] #496315
10/13/09 08:59 PM
10/13/09 08:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
the valve is open.
I've even hit the edge of the cup on the belt sander
to get a little clearance... more so with big lift
cams
Re: push rod help and ???? [Re: MR_P_BODY] #496316
10/14/09 08:30 PM
10/14/09 08:30 PM
nc
E
E
nc
thanks for all the help guys I used the adj one and got 1 1/2 treads showing and will send that off tomm. to manton I think thats right...about 140.00 next day shipping........lota help from you guys and learned a thing or 2 as well.......
