Re: push rod help and ????
[Re: B G Racing]
#496305
10/13/09 05:55 PM
10/13/09 05:55 PM
Posts: 705 Michigan
Hemiroid
Make sure that the cup is located as to get enough oil,too high and it may not get oiled properly.
I agree. And too low and it gets flung off of the adjuster threads before it reaches the cup. That's why most people shoot for 1 1/2-2 threads showing. Seems to be around the right amount to oil best and not break from being too far extended below the rocker.
[Re: Hemiroid]
#496306
10/13/09 06:22 PM
10/13/09 06:22 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
True,it depends on the style of rocker and the length of the adjuster above the ball and the oil hole location.
[Re: B G Racing]
#496307
10/13/09 07:06 PM
10/13/09 07:06 PM
Posts: 2,449 nc
earthmover
nc
it's the crane gold rocker with there adj..\\\\so would I be better off with the 2to3 showing....now I confussed
[Re: earthmover]
#496312
10/13/09 08:11 PM
10/13/09 08:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
yea I called comp and talked to a guy today told him what I needed he said he had a set that was a few thous. short I said okay mail them came home a looked on the puter at the part # ford push rods ball ball not the ball cup I need so now I'm still looking with a set on the way thats no good ...callled them back was told to just send them back good comp. to deal with but could not help with the rods this time....told me to call smith bro...
I myself would put the ones in and try them... if they are too short they wont get oil into the cup but the oil should be shooting up and hitting the end of the rocker area... the reason you dont want alot of thread sticking out is the side load when the valve is open. Put them in and presurize the oiling system while turning the engine over and see if they are getting oil.... I would waste $120 for a 1/2 thread unless they werent getting oil....... JMO
[Re: MR_P_BODY]
#496314
10/13/09 08:22 PM
10/13/09 08:22 PM
Posts: 705 Michigan
Hemiroid
As long as edge of the cup isn't hitting the bottom of the rocker and it's seeing some oil it should be ok.
[Re: Hemiroid]
#496315
10/13/09 08:59 PM
10/13/09 08:59 PM
MR_P_BODY
I've even hit the edge of the cup on the belt sander to get a little clearance... more so with big lift cams
