440 air cleaner/ duel quads #496030
10/13/09 08:57 AM
10/13/09 08:57 AM
Portland, OR
lawnman77 Offline OP
Portland, OR
I'm trying to find an air cleaner or a way to use the large 6 pak oval to adapt to my duel quad 440.
The lids are re popped, but the base is hard to find. I can adapt the bottom I'm thinking IF I can find one on line.
Thanks, Mike
Re: 440 air cleaner/ duel quads [Re: lawnman77] #496031
10/13/09 12:48 PM
10/13/09 12:48 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
What dual quad manifold are you using? If its the Edelbrock they make a nice oval that fits their intake. If you are using an Offenhauser low profile or any tunnel ram there are dual quad oval air cleaners that have an adjustable center to center distance. I believe Transdapt makes one. You could modify a 6bbl setup but I have no experience with this.
Keep old mopars alive.
Re: 440 air cleaner/ duel quads [Re: lawnman77] #496032
10/13/09 01:13 PM
10/13/09 01:13 PM
Thanks, Mike
what about the re-pops for the 426 hemis?
Re: 440 air cleaner/ duel quads #496033
10/13/09 01:29 PM
10/13/09 01:29 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Carb spacing is different.
Re: 440 air cleaner/ duel quads [Re: 62maxwgn] #496034
10/13/09 02:19 PM
10/13/09 02:19 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
There's a moparts member who reproduces the bases and lids in a fiberglass version, I think he's got a dual quad version, if not it wouldn't be hard to mod one of his bases to work.
Re: 440 air cleaner/ duel quads [Re: DaytonaTurbo] #496035
10/13/09 02:44 PM
10/13/09 02:44 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Welpers...
If you arent going to use the 6-pak cleaner and you want a regular air cleaner set up you can always go for one like mine.
It wont fit under a stock hood but I am planning on putting in a GM style cowl on my 69 (fiberglass aftermarket..dont worry fellas)
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: 440 air cleaner/ duel quads [Re: DaytonaTurbo] #496036
10/15/09 09:19 AM
10/15/09 09:19 AM
Portland, OR
Portland, OR
Would you know his name??
I did get an orginal that had been modified, but was not done "nice". A new one to do my self would be what I'm looking for.
thanks, Mike
Re: 440 air cleaner/ duel quads [Re: lawnman77] #496037
10/15/09 12:53 PM
10/15/09 12:53 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
