Re: 440 air cleaner/ duel quads
[Re: lawnman77]
#496031
10/13/09 12:48 PM
10/13/09 12:48 PM
Posts: 4,779 Holland MI Ottawa
2boltmain
Holland MI Ottawa
What dual quad manifold are you using? If its the Edelbrock they make a nice oval that fits their intake. If you are using an Offenhauser low profile or any tunnel ram there are dual quad oval air cleaners that have an adjustable center to center distance. I believe Transdapt makes one. You could modify a 6bbl setup but I have no experience with this.
Keep old mopars alive.
[Re: lawnman77]
#496032
10/13/09 01:13 PM
10/13/09 01:13 PM
I'm trying to find an air cleaner or a way to use the large 6 pak oval to adapt to my duel quad 440. The lids are re popped, but the base is hard to find. I can adapt the bottom I'm thinking IF I can find one on line. Thanks, Mike
what about the re-pops for the 426 hemis?
[Re: DaytonaTurbo]
#496035
10/13/09 02:44 PM
10/13/09 02:44 PM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
Welpers... If you arent going to use the 6-pak cleaner and you want a regular air cleaner set up you can always go for one like mine. It wont fit under a stock hood but I am planning on putting in a GM style cowl on my 69 (fiberglass aftermarket..dont worry fellas)
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
