440 to 493 w/ HP exhaust Manifolds #495870
10/13/09 12:03 AM
10/13/09 12:03 AM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
How much do you think I would gain going from a stock stroke 440 to a 493 storker (with bigger cam) compared the following combo:
440 30 over
Edelbrock heads (85cc)
10 to 1 CR
CH4B intake (air grabber)
Holley 850 DP
Lunati voodoo 268 (226/234 at .050 .493/.513) 110 LSA
HP exhaust manifolds (I know headers would be better) and 3 inch exhaust
Anyone running stock manifolds on a BB stroker? Mancini has a nice deal on a kit $1450.
thanks,
Steve
Re: 440 to 493 w/ HP exhaust Manifolds [Re: srunge55] #495871
10/13/09 12:16 AM
10/13/09 12:16 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Cam looks too small, and Andy F has made some nice power with eddies and HP mainifolds. I'd look at the 60304 voodoo for your combo
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 440 to 493 w/ HP exhaust Manifolds [Re: srunge55] #495872
10/13/09 12:20 AM
10/13/09 12:20 AM
about 1hp/cubic inch is about the norm when adding displacement. on my 470
the power difference was very small when we dynoed it with hp mans. vs 1 3/4" headers.
the noticable difference came when the header size went to 1 7/8". 2" was the catz azz.
Re: 440 to 493 w/ HP exhaust Manifolds [Re: srunge55] #495873
10/13/09 12:22 AM
10/13/09 12:22 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
"Anyone running stock manifolds on a BB stroker?
Dave Dudek comes to mind....
Re: 440 to 493 w/ HP exhaust Manifolds [Re: StealthWedge67] #495874
10/13/09 01:10 AM
10/13/09 01:10 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
bsb67 ? has a 67 charger with 500? and manifolds. I think he must be making about 900 lbs-ft of torque with it.
Re: 440 to 493 w/ HP exhaust Manifolds [Re: srunge55] #495875
10/13/09 08:56 AM
10/13/09 08:56 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The manifolds will hold it back a bit, but it will still be a measurable improvement. You will like it.
Re: 440 to 493 w/ HP exhaust Manifolds [Re: srunge55] #495876
10/13/09 11:00 AM
10/13/09 11:00 AM
AndyF Offline
AndyF  Offline
I've written a bunch of articles on similiar combos, you can find them on this board or on the net. I also covered the topic in my book.
Short answer is that combo will work just fine as long as you use the correct camshaft. The Mopar Performance .528 solid will work great or call Dwayne at Porter Racing Heads for a specific recommendation. The vast majority of "catalog" cams will not work very well for that application. Most catalog cams have too much overlap to work with exhaust manifolds and you'll end up with a dog. The correct cam will make more power than your chassis can handle.
