Re: oil coming out of dip stick
[Re: moparsrule]
#495730
10/12/09 08:14 PM
10/12/09 08:14 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You either have a bad PVC or lots of blow-by. The engine is building up pressure inside. For your sake, I hope it's not compression blowing past the rings.
[Re: moparsrule]
#495736
10/12/09 09:05 PM
10/12/09 09:05 PM
feets
Senior Management
Senior Management
Irving, TX
If the valve covers have hols in them for the PCV/breather than there's nothing wrong with them. I don't want to sound snotty, but you did use a PCV/breather grommet with a hole, not one of the grommet looking plugs right? We made that mistake once as a kid. That poor little 351 Cleveland blew oil out everywhere.
[Re: Crizila]
#495745
10/14/09 12:51 PM
10/14/09 12:51 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
I've also got a set of MP alum valvecovers on one of my 440s.
Sometime after installation, after I started driving the car again, I noticed a HUGE amount of oil all over the intake, water housing, etc. So much leakage that it is impossible to determine where it came from.
Thinking that maybe the stainless v.c. bolts were 'lengthening' due to engine heat (and maybe releasing the seal on the gasket), I installed regular steel bolts. No change.
After that I found a thread on Moparts about v.c. baffles (or lack of) in alum valvecovers -- I am next planning to put steel covers back on and see what happens.
To the OP: Do a compression check. You've got a smallblock and easy sparkplug access, so it's only an hour job. It'll be good baseline data for you in the future anyway.
After that, throw a set of steel covers on and see what happens.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Fury Fan]
#495746
10/14/09 02:07 PM
10/14/09 02:07 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
I dont know my kid rums the MP aluminum covers on his OE 62 413.He beats the snot out of it and only runs 2 breathers as I do on my 440 thats built.Neither have any blow back problem.Had a set on his built 360 also with just 2 breatgers and had no problems with it either.I want someon to explain how valve covers can push oil out the dipstick.Unless they are totally sealed its not going to happen.Oil pump wont cause it either as we run hi vol hi pressure pumps in all our motors.Id say the engine has blow by or its not releaving pressure.As said new dosent mean good.Installed too many new parts to know that as I wrench for a living.Rocky
Chrysler Firepower
