oil coming out of dip stick #495729
10/12/09 08:07 PM
10/12/09 08:07 PM
Hurricane, WV
moparsrule Offline OP
Hurricane, WV
I have a 74 Dart with a 360 that has been rebuilt that has oil coming out of the dip stick tube. It has mopar performance valve covers which I think may be the problem but I was hoping someone could help me, I hate to put the factory style valve covers back on, is there any other after market ones that look great that will work better? I installed a new pvc with new hose on drivers side rear with hose going to bottom of carb and a new breather on pass side front with hose going to factory breather. Oil comes out when driving at low rpm's and not at an idle, I have not drove the car much due to not having license on it but I figure it will get worse at higher rpm's. Can anyone please help? I hate to get oil on a new painted motor.
Re: oil coming out of dip stick [Re: moparsrule] #495730
10/12/09 08:14 PM
10/12/09 08:14 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You either have a bad PVC or lots of blow-by.
The engine is building up pressure inside. For your sake, I hope it's not compression blowing past the rings.
- Stu Harmon
Re: oil coming out of dip stick [Re: moparsrule] #495731
10/12/09 08:21 PM
10/12/09 08:21 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Not sure why it would be the valve covers as long as you have the correct PVC and breather.
You didn't by chance overfill it with oil did you? What kind of oil pump was put back in the engine when it was rebuilt?
Re: oil coming out of dip stick [Re: moparsrule] #495732
10/12/09 08:24 PM
10/12/09 08:24 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
you might need baffles in those valve covers if they are not there.
Re: oil coming out of dip stick [Re: moparsrule] #495733
10/12/09 08:35 PM
10/12/09 08:35 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Feets pretty much has it. True, non-production valve covers generally have poor baffles compared to stock, but they still they seem to work OK. You either have a defective pcv valve or a defective [ clogged ] breather or extreme blow by. Sometimes the rings get put in upside down. If that's the case, they definitely won't seal. Hope it's the breather or pcv. Good luck.
Re: oil coming out of dip stick [Re: 5spdcuda] #495734
10/12/09 08:55 PM
10/12/09 08:55 PM
Hurricane, WV
Hurricane, WV
the pvc and the breather are both new and I don't know what kind of oil pump was installed, it was done before I bought the car. I have heard of others having problems with these valve covers and I was told that mopars build alot of crank case pressure so the motor needs to breath realy good.
Re: oil coming out of dip stick [Re: moparsrule] #495735
10/12/09 09:00 PM
10/12/09 09:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Mopars don't have any more crankcase pressure than any other motor. As said you either have a bad PCV breather set up or excessive blowby.
Re: oil coming out of dip stick [Re: moparsrule] #495736
10/12/09 09:05 PM
10/12/09 09:05 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If the valve covers have hols in them for the PCV/breather than there's nothing wrong with them.
I don't want to sound snotty, but you did use a PCV/breather grommet with a hole, not one of the grommet looking plugs right?
We made that mistake once as a kid. That poor little 351 Cleveland blew oil out everywhere.
- Stu Harmon
Re: oil coming out of dip stick [Re: stumpy] #495737
10/12/09 09:09 PM
10/12/09 09:09 PM
Hurricane, WV
Hurricane, WV
Is there a way to check for excessive blow by without tearing the engine apart?
Re: oil coming out of dip stick [Re: moparsrule] #495738
10/12/09 09:13 PM
10/12/09 09:13 PM
Hurricane, WV
Hurricane, WV
the grommet does have a hole and I don't mind you asking because it could happen, I do make mistakes also and I'm not afraid to admit to them.
Re: oil coming out of dip stick [Re: moparsrule] #495739
10/13/09 11:51 PM
10/13/09 11:51 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Compression leak down test. Compression test.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: oil coming out of dip stick [Re: Rug_Trucker] #495740
10/14/09 07:40 AM
10/14/09 07:40 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
run the motor. take off the breather. put a piece of stiff paper over the breather grommet. it should be sucked against the grommet. if it doesnt, you have blow by or the pcv isnt working
Re: oil coming out of dip stick [Re: aarcuda] #495741
10/14/09 08:42 AM
10/14/09 08:42 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Too much oil in the crank case?? lower it a quart or two?
Re: oil coming out of dip stick [Re: moparsrule] #495742
10/14/09 08:49 AM
10/14/09 08:49 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
How many miles on this rebuilt motor? Sometimes it takes running the engine under load to seat the top compression rings. Take it out and run it hard a couple times and see if that doesn't solve the problem.
Re: oil coming out of dip stick [Re: aarcuda] #495743
10/14/09 09:07 AM
10/14/09 09:07 AM
Az
Crizila Offline
Crizila  Offline
Az
Fastest 300
Re: oil coming out of dip stick [Re: moparsrule] #495744
10/14/09 12:43 PM
10/14/09 12:43 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Just because it's new, don't assume it's good. Many years ago, I put on a new PCV valve, and started blowing oil out everywhere. Turned out the PCV valve was defective.
Re: oil coming out of dip stick [Re: Crizila] #495745
10/14/09 12:51 PM
10/14/09 12:51 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I've also got a set of MP alum valvecovers on one of my 440s.
Sometime after installation, after I started driving the car again, I noticed a HUGE amount of oil all over the intake, water housing, etc. So much leakage that it is impossible to determine where it came from.
Thinking that maybe the stainless v.c. bolts were 'lengthening' due to engine heat (and maybe releasing the seal on the gasket), I installed regular steel bolts. No change.
After that I found a thread on Moparts about v.c. baffles (or lack of) in alum valvecovers -- I am next planning to put steel covers back on and see what happens.
To the OP:
Do a compression check. You've got a smallblock and easy sparkplug access, so it's only an hour job. It'll be good baseline data for you in the future anyway.
After that, throw a set of steel covers on and see what happens.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: oil coming out of dip stick [Re: Fury Fan] #495746
10/14/09 02:07 PM
10/14/09 02:07 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I dont know my kid rums the MP aluminum covers on his OE 62 413.He beats the snot out of it and only runs 2 breathers as I do on my 440 thats built.Neither have any blow back problem.Had a set on his built 360 also with just 2 breatgers and had no problems with it either.I want someon to explain how valve covers can push oil out the dipstick.Unless they are totally sealed its not going to happen.Oil pump wont cause it either as we run hi vol hi pressure pumps in all our motors.Id say the engine has blow by or its not releaving pressure.As said new dosent mean good.Installed too many new parts to know that as I wrench for a living.Rocky
Chrysler Firepower
Re: oil coming out of dip stick [Re: therocks] #495747
10/16/09 10:39 PM
10/16/09 10:39 PM
Hurricane, WV
Hurricane, WV
I done a compresion check and all cylinders were 108 to 120 range. I pulled the pvc hose off the carb and it kills the engine. I will take the car out this weekend and run it some more if it does not rain. Thank you for all your help and support.
